Model A 6v pos to 12v neg for a RETARD
Discussion in 'The Hokey Ass Message Board' started by striper, Apr 28, 2013.
  1. striper
    striper
    Hope I don't offend anyone there! I'm referring to myself.
    I have a 29 A that I want to convert to 12v negative earth. I have swapped bulbs, headlights etc. I have a 12v coil ready to go. I know switches are generally OK with the change and starters seem to cope as well. The only electric gauge is an ammeter, so I figure that should be OK too.
    It was running a Delco alternator when I got it. Do they care if it is 6 or 12 volt?
    So I connect the coil for negative earth, what else do I need to change or swap polarity on?
    Thanks
    Pete
  2. cherokee_64
    cherokee_64
  3. striper
    striper
    Thanks for that. I'll have a read. At least I know how to read.
  4. striper
    striper
    OK. For anybody else doing this conversion I read through Cherokee64's link. Good info. Things I need to also do according to that link: change to a 12 v solenoid on the starter, reverse the polarity of the wiper motor (and heater fan if I had one), replace the condenser with a 12 v one. I'm off to the shed.
    Anyone happen to know what 12 v solenoid interchanges with an A model starter?
    Thanks
    Pete
  5. tommy
    tommy
    The condenser is not voltage specific.
    Just getting a 12V solenoid may not work. 6V Ford solenoids get energized when the small terminal is grounded by the Ford starter ****on. a 12 V Ford solenoid is energized when 12 Vs is applied to the small terminal. The 6V unit is supplied with power internally where you can't see it. If you go with a 12 solenoid you will need a 2 terminal starter ****on and some wiring to supply the small terminal with the 12volts when the ****on is pushed. It's very easy once you know what is required.
  6. striper
    striper
    Thanks Tommy. I had a look at the condenser and even checked with my local auto elec. Dead right I don't need to change that. I also had a look over on Fordbarn and lots of those guys have had no problem leaving the 6v original and running 12v. I'll give it a try.
    Pete
