SBC in a ford?
Discussion in 'The Hokey Ass Message Board' started by TulsaChokehld, Jan 16, 2005.
  1. TulsaChokehld
    TulsaChokehld
    from Tulsa OK
    OK, I have a question for anyone who can or is willing to answer it. I have a Chevy 350 that is waiting for a vehicle to be put into. Well, yesterday in my regular travels around town, I saw a early 50's Ford PU for sale. Unfurtunately, it was in a fenced in lot with barbed wire around the top of the fence, so I couldn't get too close to it to check it out. Also, I couldn't see a number to call about how much the truck is. Then I began to think about it.... How much of a pain in the *** woud it be to get a SBC to fit into that generation ford?
    Like I said in the begining, any and all info is welcome.
    Now, onto my biscuits and gravy, I will return shorty to see if anyone has responded.
  2. TulsaChokehld
    TulsaChokehld
    from Tulsa OK
  3. Dirty2
    Dirty2
    There is lots of room in a 50's ford truck to put any motor in !!!
  4. Deuce Roadster
    Deuce Roadster
    I have had a few of the 1948 to 1956 Ford picups with a SBC in them........real easy to do. Automatic transmissions make it a lot easier. I used a crossmember kit from Speedway. It is too long (on purpose) and you just trim it to the correct width and weld it in. Then I used a piece of box tubing and made the transmission crossmember. I installed a 59 Ford F100 rear in mine. It is a 9 inch so I could easily change the rear ratio to a 3.25 (highway driving).
  5. Fat Hack
    Fat Hack
    from Detroit
    Several companies make swap kits to drop SBCs into early 50s Ford peekups...real popular with rodders since about the late 50s, actually!
    A dude in my 'hood built a 50 Ford pickup on a mid 70s Chevy truck frame and made it fit/look/work well...was his sunny day driver for YEARS with a stone stock, but fully refurbished Chevy truck ch***is and 350 4v.
  6. HOTRODPRIMER
    HOTRODPRIMER
    You gotta be kiddin' me,,,,,,I thought they put SBC in fords from the factory! [​IMG] [​IMG] [​IMG]HRP
  7. Upchuck
    Upchuck
    from Canada BC
    [ QUOTE ]
    [/ QUOTE ]
    [​IMG] [​IMG] [​IMG] well I dunno about them coming installed but they were designed for the eventual swap [​IMG]
  8. TulsaChokehld
    TulsaChokehld
    from Tulsa OK
    Thanks all. that is basicaly what I was asking. I didnt knwo if it was going to be a pain in the *** to do. Now that I knwo it is a relativlely easy swap, I will definately be trying to get ahold of the guy selling it. Hopefully, he doesnt want too much for it and I can find a place to keep this ****ing thing.
  9. Rocklock
    Rocklock
    And that is how to improve a sbc, put it in a real truck... but it sure cheapens the Ford.
  10. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    <font color="green">I thought those old Fords came with Chevy small blocks in them already?
    Mama Rash was after Christmas shopping and saw a 32 Ford model going cheap, called to see if I wanted it. DUH. She gets it home and I'm looking it over and the damn thing has an SBC in it, ramhorns and all!
    </font>
  11. Dirk35
    Dirk35
    IF you get the truck, I have a 48 Ford PU cab (been wrecked on p***enger side, but the gl*** and the majority of it is good) and the back half of the frame with a checvy 10 bolt rear-end Ill give you for free if you haul it away.
    Free, Free, Free.
  12. Roothawg
    Roothawg
    I put a 350 in my 53 Ford F100. It was easy. Just don't buy the motor mounts from No Limit. They are a joke.
  13. Crosley
    Crosley
    from Aridzona
    small block chev 350 , mustang II front suspension, ford 8 inch maverick rear diff under this 1961 Dodge Lancer.
  14. McGrath
    McGrath
    I don't know about Fords from the 50's, but my '65 F100 didn't even require special mounts for the SBC swap. I used '69 Chevy Truck motor mounts, and it set right down in place of the original 352 with no other modifications. I did have to make a crossmember for the ******, but thats pretty simple.
    On hindsight though, I should have moved the Frame mounts forward about an inch before dropping the SBC in. The extra room for the HEI distributor would have been nice... [​IMG]
  15. corrosive
    corrosive
    from 08070
    I have a 59 f100 .im doing a sbc swap. do u need to remove the old k-member out ? it had the six and three on the tree.
  16. Jalopy Joker
    Jalopy Joker
    so, have a Chevy motor laying around and going to put it in a Ford truck that is likely not For Sale. the pain that we put ourselves through trying to figure this stuff out..
  17. go-twichy
    go-twichy
    i was still in my fortys when this thread started!
  18. hotroddon
    hotroddon
    Holy mother of old thread coming back from the grave!
  19. Leadsled612
    Leadsled612
    My SBC 350 in a very roomy 50 Mercury!!
  20. black 62
    black 62
    from arkansas
    it is natures way...
  21. flathead_10
    flathead_10
    from Kansas
    Man a sbc in. A ford now Ive seen it all
  22. sedanbob
    sedanbob
    This thread is almost old enough to prove that an SBC in a Ford is Traditional.
  23. steve185
    steve185
    Nooooooooooooooooooooooooooooooooooooooo
  24. old soul
    old soul
    from oswego NY
    Im a chevy guy. But im starten to dig old fords. Its kind of a discrace to put a chevy motor in a ford. yucky!!! not cool in my eyes. Fords are the roots of this hobby. I think we should save as many old fords as we can. Ok im done running my mouth.
  25. davidh73750
    davidh73750
    Last month or so a somewhat looking original F1 on fast n loud looked like it had a old 283 in it. For a cruiser I don't mind a 350 olds or caddy motor. A roller 302 is good too what ever your budget allows just get it on road ASAP
  26. THR1LL3R
    THR1LL3R
    from St. Louis
  27. Ester Eddie
    Ester Eddie
    from Alaska
    Ha I was reading through the thread .I got to you and checked the date! ha:eek:
  28. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    Bump For Ford Sourpusses to weep some more :)
  29. tfeverfred
    tfeverfred
    First post and it's an 8 year old thread. Cl***ic FNG.
  30. Rickybop
    Rickybop
    This thread is so old it needs sandblasting and patch panels.
