Dodge Starter Solenoid
Discussion in 'The Hokey Ass Message Board' started by S2X01, Apr 30, 2013.
  1. S2X01
    S2X01
    So...
    My starter solenoid is on the inner fender. After chasing down the "trigger" wire, I found it goes to the transmission. And then it seems to go to the brake pressure switch. Why? And why can't I start it with the key/ignition? Does the system need to see brake pressure in order to start???
  2. 50dodge4x4
    50dodge4x4
    It would help to know a little about your car. What is it? Does it have the 6 volt positive ground or 12 volt negative ground? Is it original or modified? Automatic or manual trans? Gene
  3. S2X01
    S2X01
    54 Royal. 6V negative. 2 speed auto.
  4. S2X01
    S2X01
    Oops....6V positive ground is what I meant.
  5. FIDDLER
    FIDDLER
    from VIRGINIA
    Sounds like you have neutral safety switch on the transmission, and the brake energises it when the pedal is down, especially if you do not have a starter ****on, or a start position on you keyy switch. My guess is put in park, push brake pedal hit stater ****on or key switch car cranks just a guess
  6. S2X01
    S2X01
    That's kind of what I figured. Time to see if the brake system leaks or not!
  7. Dane
    Dane
    from Soquel, CA
    Probably needs to be in park with your foot on the brake to start.
  8. Rusty O'Toole
    Rusty O'Toole
    The brakes shouldn't have anything to do with the starter or transmission. The wire that goes to the neutral safety switch is a ground wire. The switch grounds the wire when the trans is in neutral or park.
  9. Mr48chev
    Normally no it wouldn't but if you read what he wrote in the first post in the thread closely the exciter wire to the solenoid is wired through both a switch on the trans (neutral switch) and the brake switch meaning that either the factory or a previous owner wired it though the brake switch as a secondary safety procedure.
  10. S2X01
    S2X01
    Everything looks original....and dirty.
    The shifter/transmission has no park. Just RNDL. I'm ***uming it's a safety feature so there's no way you can accidentally try and start the car if it's in D.
    I'm gonna fill the brake system up today and see what happens. Worst case scenario, I'll just temporarily wire in a momentary switch as a byp***.
