Customs Shoebox, need to match front with Bagged Rear
Discussion in 'The Hokey Ass Message Board' started by TULSA, Jan 29, 2013.
  1. TULSA
    TULSA
    from Tulsa
    Alright guys here is where I am at. The shoebox I just bought has the full Gambino setup out back. The front is stock cut coils. Rides like ****, rides on bumpstops.
    I am looking to put bags up front. I searched a few topics with not too much luck. From what I see, it looks like running lowering knuckles and the correct bags is the way to go. Am I missing something? I would love to see some pictures with how everyone is setup up front as well...
  2. TULSA
    TULSA
    from Tulsa
    Btt
    Sent from my DROID device using the TJJ mobile app
  3. Tim
    Tim
    from KCMO
    Have you looked into switching spindles side for side? Maybe run the popular aero star springs and change your spindles side to side for the drop spindle effect and you'd get pretty close I'd think. Tech o matic has the spindle swap info if you've never seen it
  4. TULSA
    TULSA
    from Tulsa
    You mean swapping the knuckles or uprights and spindles? Is Tech o matic a member here or a website?
  5. 226 flattie
    226 flattie
    from orange,ca
    I think what Tim meant to say was Turing the uprights upside down. I put Fatman drop uprights on my shoebox stock springs . Aerostar springs are cheap favorite to some. Turning the spindle upside down or fron side to side will not help any.
  6. 226 flattie
    226 flattie
    from orange,ca
    If you need help , I can share with you how to do it . Pm me if you like .
  7. TULSA
    TULSA
    from Tulsa
    Thanks I searched his terms and found alot. Looks like switching the uprights upside down drops about 3" and most say there is no difference from the Fatman or Jamco, just have to adjust steering arm with torch for correct alignment. That sounds like what I need to do for adding bags up front.
  8. 226 flattie
    226 flattie
    from orange,ca
    Some grinding may be involved for clearance when flipping uprights. Fatman came out with the drop uprights before jamco did.
  9. Tim
    Tim
    from KCMO
    The tech o matic is a sub forum of the Hamb like the cl***ifieds if you didn't find it yet. It's a post I started and it's ***led something like "Rocky's spindal swap" hope you find what your looking for :)
  10. BESHAN48
    BESHAN48
    i dont have the answer on you question, but i LOVE your headlights!
  11. 51fordshoebox
    51fordshoebox
  12. TULSA
    TULSA
    from Tulsa
    Ok so what about the bags? I need two bags for front and mounting plates. Best source?
  13. hombres ruin
    hombres ruin
    try airbagit.com..I use bags up front,i use firestone bags which i find work best,they have never burst or herniated on me.I use two viair compressors and parker fittings.
  14. chaddilac
    chaddilac
  15. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
  16. hombres ruin
    hombres ruin
    Here are the pics of the front bag set up with the firestone bags and recessed shocks.
      491.8 KB
      488.1 KB
      484.8 KB
  17. TULSA
    TULSA
    from Tulsa
    Thanks for the info... The front end is ready to drop!
  18. hombres ruin
    hombres ruin
    Post up some before and after shots.
  19. TULSA
    TULSA
    from Tulsa
    Yeah once I get further along I will. This is basically how I got the car other than bumpers and few things
  20. happy hoppy
    happy hoppy
    Hombres Ruin, do you have the part number or bag size used in your set up?
    Was the shock recessed into the frame for tire clearance?
    thanks!
    David
  21. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
  22. TULSA
    TULSA
    from Tulsa
    Front is bagged now. Just need shocks up front. Also getting ready for paint next week.
  23. TULSA
    TULSA
    from Tulsa
    And yes. I did this too. Front would be lower in pics above, but inner fenders are sitting on tires.
  24. 51fordshoebox
    51fordshoebox
    tulsa, that car is slick..if you ever decide you want a 31 sedan project instead let me know..
  25. Caddy-O
    Caddy-O
    Great car Tulsa.....Did you not like the bias ply tires that were on it?
  26. TULSA
    TULSA
    from Tulsa
    Thanks. They looked good but I did not like em. I won't post more pics as ive got another thread with the paint but one will not hurt...
  27. TULSA
    TULSA
    from Tulsa
  28. lorodz
    lorodz
    Very nice color combo looks like a root beer float...love it..
