Edelbrock banjo fitting washer help
Discussion in 'The Hokey Ass Message Board' started by unkledaddy, May 2, 2013.
  1. unkledaddy
    unkledaddy
    I have a Edelbrock 1806 with a single-feed fuel line and banjo fitting.
    I need a couple of replacement washers for the banjo fitting and they don't seem to be available without buying the fitting. I don't want to take the one I have off to measure it, but I think it's about 3/8" ID.
    Can anyone tell me where I might pick up a couple, and what size?
  2. i think it is bigger than 3/8" ID , and i also think they are available from Mr Gasket ...i could be wrong? if i was at work i'd check the catalog for you
  3. unkledaddy
    unkledaddy
    The nut is 3/4" and the washer is very narrow from OD to ID, so I think you're right about it being bigger than 3/8". The tech rep at Summit suggested I try the hardware store for 3/8" so I never gave it a thought. I'll see if Mr. Gasket has an online catalog.
    Appreciate you.
  4. pinkynoegg
    pinkynoegg
  5. unkledaddy
    unkledaddy
  6. Buckster
    Buckster
    Check with NAPA. They have the copper washers for the hose-fittings on a disc brake caliper. I believe they have an illustrated catalog page that will give the dimensions.
  7. gatz
    gatz
    If there's one in your area, might try an Allis Chalmers (AGCO) dealer.
    Certain Roosa-Master inj pumps used this style of washer on the banjo fittings; and IIRC, they're 3/8 i.d.
  8. bonechop
    bonechop
    from NW Indiana
    have you tried your local Harley dealer? Or even A Jap bike dealer.....
  9. unkledaddy
    unkledaddy
    UPDATE
    I called the Edelbrock tech line and was told those washers are hard to find, but the tech said he'd send me a couple. If it happens that will be great customer service.
    Thanks for all the input.
  10. outlaw256
    outlaw256
    ive got 2 edledbrock carbs on my ranchwagon and ive replaced those washers with some from oreillys. just like the ones in the pics pinkynoegg put up. been there for a few yrs. and ive had them off a few times .if you dont get yourss from the rep. ill look for the package they came in and see if its got a part# on it...
  11. Terrible80
    Terrible80
    Most harbor freight junk is just that, but they do sell a washer ***ortment that work okay and are really cheap. Under $10.
  12. unkledaddy
    unkledaddy
    Thanks, I'll holler if mine don't show up.
  13. ago
    ago
    from pgh. pa.
    The inside dia. is 5/8" outside dia. is 7/8"
    Ago
  14. woodiewagon46
    woodiewagon46
    from New York
