Can original glass be resurfaced , polished and saved?
Discussion in 'The Hokey Ass Message Board' started by 55Thunderboy, May 4, 2013.
  1. 55Thunderboy
    55Thunderboy
    from NYC
    I have tried the kit from Eastwood 15 years back with ill results
    I have one of my cars that really needs new glass or have the glass resurfaced. I really looked into repo but the glass is thinner and might not fit right and that will become a costly headache
    I mean in theory any hard surface can be polished and resurfaced but who can do this on auto glass professionally?
  2. C-1-PW
    C-1-PW
    To my knowledge, no one.
  3. You cannot do it without a distorted outcome. Buy new glass, you'l be happier!
  4. pride63
    pride63
    You cannot polish glass without causing distortions I'm afraid.
  5. I was an auto glass guy and sometimes did a polish job here and there.
    I used jewelers rouge and a polishing pad made for taking scratches out of glass. The rule of thumb, if your fingernail catches on a scratch, then its too deep. I've done windshields where the glass has become clearer with about an hour effort (I charged per hour with no promises on outcome). Some people were satisfied with the results as the glass was significantly clearer, while other expecting perfection - disappointed.
    I know what you mean about new glass, it's thinner and sometimes fit is not so great. I would recommend either glass from PPG or LOF for the best fit.
  6. PPG is now produced in China too
  7. Tnomoldw
    Tnomoldw
    Scratches, dings and dents are commonplace when it comes to cars[​IMG]. Flying debris on highways, careless people who park their cars next to you and accidents all may result in damage to the body or windows of your car. Surface scratches to your glass windshield may be eliminated using a car polish and mark remover produced by 3M. Car polishes may be purchased from most automotive stores and can save you a costly trip to a glass and auto body specialist
    Read more: How to Remove Scratches From Window Glass Using 3M Car Polish | eHow.com http://www.ehow.com/how_6619596_remove-using-3m-car-polish.html#ixzz2SNymb0jc
  8. weps
    weps
    from auburn,IN
    When I worked at a glass fab plant we would save some scratched pieces by polishing on a giant (5 ft) diameter felt wheel that we sprinkled ground up walnut shell dust on. This took a lot of time, and was usually for prototype pieces.
    If you can catch your fingernail on it, it went into the scrap hopper.
  9. Chevy Gasser
    Chevy Gasser
    Yes, glass can be polished. I put a used tinted windshield in my '55 Chevy 20+ years ago. It had wiper rash and a spot on the left side where the stainless wiper arm rubbed the glass, about 3" long. It was a very noticeable rough area up to 1/4" wide. A couple hours work with a felt arbor with cerium oxide and it was totally clear. The "burn" area was only slightly distorted but never bothersome. Cerium oxide kits are available, maybe your local glass shop would have some. What have you got to loose? If you don't want to use it I guess it is scrap anyway, right?
  10. 55Thunderboy
    55Thunderboy
    from NYC
    well my glass has hundreds of nicks in i from grinding or welding by someone in the past that is what i was wondering if it could be resurfaced enough to fix this but it looks like the answer is no. i ned to start searching for good used glass now the china stuff is very expensive.
  11. Chevy Gasser
    Chevy Gasser
    What kind of glass ya lookin' for. Did you post in classifieds?
