Projects My AV8 flathead build.. blown...
Discussion in 'Traditional Hot Rods' started by hotrodderhaag, Jan 28, 2013.
  1. Tnomoldw
    Tnomoldw
    :)Awesome little car !!:cool::D
  2. hotrodderhaag
    hotrodderhaag
    Radiator is finally welded. Thanks John! [​IMG]
  3. hotrodderhaag
    hotrodderhaag
  4. brian55lvr
    brian55lvr
    from ma
    looks nice----i have be-utiful flowers all over my gr*** too---lol
  5. hombres ruin
    hombres ruin
    great ride,very jelous ha
  6. TexasSpeed
    TexasSpeed
    from Texas
    The magic question is.. Did you push it onto the gr*** or drive it there? :)
  7. hotrodderhaag
    hotrodderhaag
    Damn I hoped no one was gonna ask that. ! I pushed it......... :(. Just for now. Lol
  8. TexasSpeed
    TexasSpeed
    from Texas
    No worries.. You're flying on this one! You'll be driving it before you know it.
  9. hotrodderhaag
    hotrodderhaag
    I did get the carbs cleaned and fresh gaskets to seal them up good .. Still working on pedal brackets . I'm really hoping to be able to run it soon
  10. hotrodderhaag
    hotrodderhaag
    Had the water tunes bent up today out of stainless. Also finally got my pedals all mounted. Still need to heat and bend the stems just a hair. But they fit great
  11. I think these super chargers had a inter cooler. Will you hook up the cooling lines?
  12. Rickybop
    Rickybop
    First time I've viewed your thread, HRH. And the first time I've ever seen a generator driven off the supercharger like that. Neat! Best wishes with the rest of your build.
  13. hotrodderhaag
    hotrodderhaag
    No I'm not going to. It says right in the factory do***entation that its for colder weather to heat the intake air. I'm not worried about it. It's never gonna run in colder weather
  14. hotrodderhaag
    hotrodderhaag
    as i said before i need to trim my fan down an inch... so to ensure that all four blades get done equally, or as close to it as possible, i made these stick on templates that fit the end curve of the blade, and give me the new curve approx an inch lower. this wil make everything fit nice in between the rad hoses.
  15. box50
    box50
    Looks good my friend,
  16. hotrodderhaag
    hotrodderhaag
    I managed to get the fan cut down and put on. Also heated and tweaked the pedals as best as I can to fit the car comfortably.. I also got the exhaust welded up and I heated and dimpled the fire wall behind the fuel pump stand for a lil more clearance. Installed a high volume fuel pump also. Making progress
  17. Hotrodmyk
    Hotrodmyk
    WOW this is coming along so well! Won't be long now.
  18. NATESBPD
    NATESBPD
    PLEASE! Post a video of the motor running.. it has got to sound cool! Love the build!
  19. Hotrodmyk
    Hotrodmyk
    X2 for sure
  20. hotrodderhaag
    hotrodderhaag
    im hoping friday after work she will be ready to fire. i know im pretty damn excited about it. its been a fin projecto so far. cant wait to drive it and take it to some local cruise ins... alot of guys locally never see a flathead actually on the road. atleast thats the comments i always get
  21. hotrodderhaag
    hotrodderhaag
    It's alive and running. Will post several videos tomorrow. Here are a few pics... Got alot done today .engine seems to run hot even with the fan . I need to put restrictive plates in since I'm not running thermostats
  22. hotrodderhaag
    hotrodderhaag
  23. cederholm
    cederholm
    WoW! Very nice!!
  24. hotrodderhaag
    hotrodderhaag
  25. '54Caddy
    '54Caddy
    Embedded them for you.
    Man this car is coming out great! I love the supercharger!!!
  26. hotrodderhaag
    hotrodderhaag
  27. Mart
    Mart
    It's Aliiiive!
    Nice job.
    Mart.
  28. Saxon
    Saxon
    from MN
    Car looks and starting to sound great!
    An ol' flathead roundyround racer I visit at his shop occasional, told me they used to run the 37 block with the waterpumps in the block, then flip the early heads (left-right) so the outlets are in the back of the block, to increase flow to the back cylinders and block. It would require someone to cut up the firewall, which you aren't doing. Just some useless information. :]'
    Anyway, nice car and build.
  29. hotrodderhaag
    hotrodderhaag
    Saxon. That makes alot of sense. It seems mine with a four core radiator still gets hot after a while of running in the garage
