How to split the windshield frame?
Discussion in 'The Hokey Ass Message Board' started by nhmikel, May 8, 2013.
  1. nhmikel
    nhmikel
    from NH
    I have a 1936 Dodge truck windshield frame. The overall cond is good.
    Except all of the screws holding it together. Soaked them up good and still
    cannot get them out. I am thinking the screws are "fixed" to the square stock inside?
    So .....whats the best way to split it, use it and not destroy it in the process?
  2. nhmikel
    nhmikel
    from NH
    Advice please
  3. TORR
    TORR
    from BOSTON, MA
    Did you try heat yet, or are you trying to save the gl*** and gasket?
    I've used a impact screwdriver before with success.
  4. Fenders
    Fenders
    I've had good luck with Kroil, sometimes had to let something soak for a week though. (Kept it wet, a spritz once a day.)
  5. nhmikel
    nhmikel
    from NH
    No heat yet...and no gl*** to save
    Would heat distort the rails?
  6. 1947vert
    1947vert
    from Minnesota
    I would try some heat. Heat the screws, let them cool, repeat several cycles hoping to break the rust. Finally heat and try with the screw driver. If this doesn't work you will have to drill them out. Best on a drill press rather then a hand held drill. Best of luck to you.
  7. TORR
    TORR
    from BOSTON, MA
    If you end up stripping out the screw head, try the old trick of welding a nut onto the screw.
    The heat shouldn't effect the rails, if you use common sense.
  8. 325w
    325w
    Drill the screws out Seperate the frame. Then drill the remainder of the screw and Retap the threads.
  9. Checkerwagon
    Checkerwagon
    I agree with 325w, "Drill the screws out".
    nhmikel;
    "No heat yet...and no gl*** to save
    Would heat distort the rails?"
    You're thinking too much. This is basic stuff.
  10. Heat the screws with your torch till red,take a screwdriver and place it on the screw's slots and tap with a hammer a few while they're hot....
    I know you are not suppose to use a screwdriver that way,but it works and an old one can be abused
  11. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Thats how I remove just about every screw or bolt when they are stuck. Ive watched guys drill and try and use easy outs and end up with no results. I havent touched an easy out in years.
  12. nhmikel
    nhmikel
    from NH
    any other ideas?
  13. flynbrian48
    flynbrian48
    The windshield frame screws in my Diamond T were stuck, and I have twice as many (split windshields) as you. Just heat the heads up red hot, let cool, repeat. Soak with pentrating oil of your choice, then lay the frame flat on the bench, get a screwdriver with a nice sharp point that FITS the slot, and whack it with a hammer.
    That worked for me, I got all 8 out intact, and didn't damage the delicate stainless frame.
    Brian
  14. '54Caddy
    '54Caddy
    I just went through this with my Model A windshield. I wanted to use the old "weld a nut to the screw" trick, but the head was so small.
    What I ended up doing was taking an old ****py screwdriver I didnt car about anymore and tig welded it in the screw slot. The heat from the welding helps break it free and the screwdriver no longer slips out of the slot! after getting the screw out, simply cut the screw off, resharpen the screwdriver on the grinder and move onto the next screw. I did all 6 screws in my model a windshield in less than 20 minutes!
  15. Bruce Lancaster
    Bruce Lancaster
    Another thing...get a piece of 1/4" steel plate in a vise, hang frame over it with the steel up where the gl*** usetawas. Now you can tap on the screws more authoritatively, perhaps use one of those hammer type impact driver. Once you finish utterly destroying the screw head, then drillitout!
  16. nhmikel
    nhmikel
    from NH
    All good ideas thanks
  17. oldrelics
    oldrelics
    from Calgary
    X2 red hot
  18. studeynut
    studeynut
    Have you tried soaking the frame in mol***es/water mixture to remove all rust, soaking in for a week couldn't hurt. Then try previous mentioned methods.
  19. Ralph
    Ralph
  20. tommy
    tommy
    I'd save the drilling for my last resort after you have already damaged the screws and the other suggestions have failed. Kroil, heat and an impact screw driver. Trying very hard not to damage the screws. Once they break loose, it's a piece of cake.
  21. I also would not drill untill last resort, I think heat is your friend right now.
