Blast media question...........
Discussion in 'The Hokey Ass Message Board' started by Reman, May 6, 2013.
  1. Reman
    Reman
    from Florida
    What do new gl*** beads look like? I bought a used cabinet off a guy a while back and he said it had X pounds of new gl*** beads in it. It looks like soda and feels the same as soda. Just an extremely fine white powder. He swears it is gl***.....Now, I have a good bit of sandblast experience, but ONLY with sand so I have no experience with gl*** or soda. Can someone set me straight on this? Thanks
  2. Reman
    Reman
    from Florida
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Doesnt soud like gl*** beads to me. Trying to think how to describe gl*** beeds without sounding like a retard on crack, but "white powder" sure isnt it.
  4. justold
    justold
  5. ours kinda looks like white powder when it gets all broke down. How new did the seller say they were? A cabinet just keeps recycling it, dump it out the bottom, saving it, and see if there is any thing in there that resembles "crystals". I laughed when justold said "tase it", but think about it, no don't taste it, how about smelling it though.
    Fenderless
  6. raengines
    raengines
    from pa.
    gl*** beads are also used to make highway signs reflective, think more corse texture than powder. but not as much as sand.
  7. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Smelling it or snorting it? Gl*** bead is a gateway abrasive :D
  8. Bugguts
    Bugguts
    My gl*** beads look similar to powder because I'm cheap and don't want to add new till I have to. They are getting pulverized. When I look close though, I think I can still see some small round shape to them. If on doubt, get a new bag of gl*** beads and dump the old. I think I paid about $50 last time, and I make it last a long time. They definitely work well.
  9. 296 V8
    296 V8
    from Nor~Cal
    outstanding first post ... thank you so much for coming here
  10. I used some gl*** "shards" that broke down into a powder. I got them at HF.
    They made a mess...clogged my vacuum and they did not work very well to clean parts.
  11. Motomike43
    Motomike43
    Put a small amount of the material in your hand. Gl*** bead should have a slight glitter to it when the light hits it right. Soda will not reflect at all
  12. Motomike43
    Motomike43
    Also, put a small amount of the material in your hand again. Blow it into the air. Soda will dissipate into the air like a fog or cloud floating in the air before it falls. Gl*** bead is heavy. It will just fall straight to the ground like sand would. Hope this makes sense. It sounds good in my head HA
