Home-Built Steering Column With Turn Signals?
Discussion in 'The Hokey Ass Message Board' started by Buzzman72, May 8, 2013.
  1. Buzzman72
    Buzzman72
    I'm sloooooooowly working on my build of my '52 International pickup, and I paid close attention to the tech thread here on building your own steering column.
    http://www.jalopyjournal.com/forum/showthread.php?t=666232
    Well, I'm interested in building a similar column, but going one step further. I want to add turn signals...self-cancelling signals. I remember the '64 Chevelle I once owned had a simple switch for signals, but I don't recall how they cancelled. I figure I can weld up a cup for the switch, and weld in a couple of threaded tubes to mount the switch. But I want to be sure I can have self-cancelling signals...since I'm getting about the age where I don't wanna be the old codger everybody's cussing 'cause his signal's been flashing for the past 13 miles.
    Info/ideas appreciated.
  2. desotot
    desotot
    Seems I recall an article in a hotrod magazine about 35 years ago where some guy adapted a corvair set up on an early ford column.
  3. need louvers ?
    need louvers ?
    Ya, Corvair stuff is available new still and very simple. It just slides over a basic tube column and ****s up below your steering wheel. Pre 1967 Volkswagon had the same type of deal and it too is reproduced as well.
  4. charlieb66
    charlieb66
    Maybe you can incorporate a timer into the TS system. I will be installing the TS and HB indicator lights in the header panel above the windshield of my Model A. I want them up in my sight line.
  5. jjjmm56
    jjjmm56
    from FL.
    Custom chrome a motorcycle parts supplier had some self canceling units that hooked up to harley turnsignals. I think they were made by badlands.
  6. COOP
    COOP
    Speedway offers an electric switched unit that does not require any mechanical canceling system. Very simple and clean.... and adjustable.
  7. hotcoupe
    hotcoupe
    this is a column that i built for my roadster, using a VW turn signal switch.
  8. hotcoupe
    hotcoupe
    and a little better image.
  9. Buzzman72
    Buzzman72
    In the interest of keeping this discussion totally public, I received a PM suggesting I look into using a '54 Chevy truck switch. Further research showed a cancel cam that attaches to the backside of the steering wheel with two screws. Not sure if these are the only major pieces I'd need, so I'm searching for an exploded view of how the pieces all work together...and if there are any separate springs, etc. involved.
    AND...I believe I've found the exploded view I was looking for:
    http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0257.htm
  10. need louvers ?
    need louvers ?
    I'm just working on a '52 Chevy convert for a guy right now and it too has a turn signal switch that simply slides over the tube column and is available new.
  11. 117harv
    117harv
    Yes, we have all seen the running wild turn indicator on a car in front or behind us, I have done it too:eek: I think all new cars should have small lights on top of the dash on each side as most of the factory ones are hard to see or obstructed by the wheel etc...but I digress.
    Here is what I do when driving my OT ride and plan to do it on my roadster when I get to the build. I move the lever so that the signal works but dont go so far that it clicks and stays. When you are done turning or lane changing it snaps back to the center/off avoiding the dreaded, running wild signal. Making a spring loaded arm that looks vintage wouldn't be too hard...just a thought.
  12. Buzzman72
    Buzzman72
    Here's a picture of a '54 Chevy turn signal ***embly, as sold by one of the restoration parts vendors:[​IMG]
    So now I just need to measure the OD of a '54 Chevy column...
  13. jazz1
    jazz1
    If people are cussing the old codger then they are finally paying attention and will be aware and wary of your next move,,I wouldn't change a thing.
  14. pasadenahotrod
    pasadenahotrod
    from Texas
    When I was helping Burl build the 32 3W coupe we installed the signal and highbeam indicators in the header panel pointing down at the dash top. The LED lights are reflected in the dash top when operating. The dash has both gauges and idiot lights for the engine functions so it was better to move them up top.
  15. R Frederick
    R Frederick
    from illinois
    I made my column from a 65 Bronco. It's clean, simple, vintage, and self cancelling.
