Help I.D. Old Dealer attic find Steering Wheel Pont./Olds ?
Discussion in 'The Hokey Ass Message Board' started by grazy, May 9, 2013.
  1. grazy
    grazy
    A local University has been buying up local propeties and tearing them down . One was a Texaco Station building from the 1920s I was able to get permission from the owner and cleaned out the attic before the school took ownership of the property. Another one I just got into was an old dealership building that is to become a maintenace building for the school it was an Oakland Dealership that became a Pontiac / Oldsmobile Dealership up to the mid 1960's this steering wheel is N.O.S. but had no tag or part #'s on it the only # it has is a #35 on the bottom side by the end of the spoke I need to know what year and model it is for I would love to run it in a Model-A sedan project and would love to find out what the horn ****on I need looks like and what column I need to hook it to my Vega box. Thanks for the help! The knowledge on the H.A.M.B. never ceases to amaze me.
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Great rescue. It is a beauty.
  3. BJR
    BJR
    Looks early 50's to me.
  4. grazy
    grazy
    I love how it has the look of a 40 Ford steering wheel clean simple but its slightly different. Was looking for a early 50s chevy wheel but found this.
  5. jesse1980
    jesse1980
    Looks like a pontiac
  6. F&J
    F&J
    If you think it is GM and if it has fine splines, I would bet it is a "chevy" spline. My 41-48 chevy car wheel fits right onto a mid 60s chevy pickup spline, and I once tried a modern 80s jeep wheel on the same shaft, and it fit also.
    So, if you know somebody local that has a steering shaft from a GM, try the spline fit.
    If it is GM spline, then you could do all sorts of mods to any column, by using the inner chevy shaft in a different column if needed. I did that to a 40 Ford column, and put the chevy shaft in it, so I could use the 40s chevy wheel.
  7. What he said. GM had a big column shaft in some Buick/Olds/Caddy but the rest were all one smaller shaft and they used the same shaft and splines from the 1930s into the 1990s. AMC also used it, I even have some '70s AM General Army Jeep columns that would fit right on like it was made to.
  8. plymouth1952
    plymouth1952
    looks like a 48 olds
  9. grazy
    grazy
    I was googling images of interiors for different years makes and models of both Pontiac and Oldsmobile. Was begining to wonder if it was an optional or accesory wheel.
  10. grazy
    grazy
    Tried Google images for 48 Olds wheels none looked right.
  11. Could be a 1955-56 Pontiac 860-870 series standard wheel.The deluxe wheel had a full horn ring whereas the lower line cars used just the center ****on.
  12. weps
    weps
    from auburn,IN
    Pontiac. I have one just like it. Not sure of the year though.
  13. grazy
    grazy
    1956 Pontiac was similar but slightly different.
  14. grazy
    grazy
    Help still looking for answers !
  15. grazy
    grazy
    Anybody Help Please ! !
