i bet this would be simple for a sheet metal guy
Discussion in 'The Hokey Ass Message Board' started by fullsizejohn, May 9, 2013.
  1. fullsizejohn
    fullsizejohn
    I need to make the air deflector that attaches to the radiator support panel. I only need one. I have its mirror on the other side.
    Anybody willing to get me started on this? I was thinking maybe building it in strips? Or should i try to hammer it out on a stump? Any ***istance is appreciated!
    attached is a pic of what im needing...
    ps. it is more curved than it appears in the pic.
  2. pimpin paint
    pimpin paint
    from so cal
    Hey,
    That's not too tough of a panel to build, although you'll probably have some time wrapped up in building that one!
    Given the numbers that '55-'6 Fords were built in, I'd look for a replacement on ebay or the HAMB.
  3. 49ratfink
    49ratfink
  4. Last time I was at All American they had several 55/56 sedans in the yard. Check out there web sight or give them a call. Not that I against hand building one but why?
    www.allamericancl***ics.com
    These are good guys to deal with and will ship anywhere.
    The Wizzard
  5. bobss396
    bobss396
    THAT'S WHAT SHE SAID!
    Bob
  6. Are you taking about the long tube piece that goes above the wheel? Maybe we can a photo shop person to circle what you are taking about in the pic. The reason I ask is I have alot of 55/56 for frt end parts that are going to LA Roadster show this year for sale. Maybe we can get you fixed up ahead of time.
  7. big M
    big M
    I probably have some decent solid ones, if you don't decide to go the fab route.
    ---John
  8. Motomike43
    Motomike43
    From this picture I can not tell which part you need made. Can you upload a better pic or mark this picture
  9. F&J
    F&J
    It is the 90 degree big sheetmetal thing near the cowl, that the large air tube goes through.
    I like to make parts, but I think I would buy a good used one from the above posters.
  10. fullsizejohn
    fullsizejohn
    Sorry guys, dont know how to circle it. Its the piece that attaches to the front of the fender,underneath. Its spot welded to the radiator support apron and helps tie the front end sheet metal together and push the air into the fresh air duct. I wouldnt be against buying one( i bought the dvr side) but havent had luck. Thanks guys john
  11. fastcar1953
    fastcar1953
    is it the red circle that's missing? the part is like the yellow circle. that's what you need? [​IMG]
  12. tommy
    tommy
    Mine was dented from a fender bender. You could not see it with the fender on. The piece is spot welded on. I'd never attempt to try and build one without a 2 year course in metal fabrication. I have the p*** side that you can have if you want to learn metal straightening. They are not that hard to find so don't spend stupid money on a nice straight one. it all one piece over to the radiator. You might be able to buy a rusty one and use the spot welded piece. They rust out down low where they bolt up to the bumper splash apron.
  13. 19Fordy
    19Fordy
    If you have to pay to have one made, it will cost you way more than one from a junk yard.
  14. fullsizejohn
    fullsizejohn
    its the yellow circle....ok i will keep hounding the fleebay hahaha
    thanks all john
  15. Jeff Walker
    Jeff Walker
    I can probably supply you one. PM me.
