would you replace 302 with 352?
Discussion in 'The Hokey Ass Message Board' started by 65fordguy, Apr 26, 2013.
  1. GEEZZER
    GEEZZER
    Not no.....but....... HELL NO!
  2. frank rempel
    frank rempel
    from kingman az
    NO WAY!! A 352 is a dog. A 272 or a 292. much much better engines. Lose the boat anchor! Stay with the 302, excellent motor. Frank R
  3. flatout51
    flatout51
    A FE will walk all over a yblock.
  4. I agree. Im of the opinion that if ford had came out with the FE in 1954 instead of the Y block. tri five chevys wouldnt be as popular as thay are. Back in the day I always pulled out the rear main leaking dry rocker arm blowby puffing Y blocks and swapped in a FE. Even a 2 bbl 352 with a stick would out run a 312 4bbl and get better gas milage when doing it.
