Features Econoline Madness Who's got one?
Discussion in 'The Hokey Ass Message Board' started by kornfedlifer, Apr 25, 2007.
  1. von zipper
    von zipper
    Dave Grohl from the Foo Fighters has one! ImageUploadedByTapatalk1364609519.656828.jpg
    droppedstepside likes this.
  2. ray
    ray
    from colorado
    wasn't it a roof from a 2nd gen econo?
  3. Hogride
    Hogride
    Hay Guys ! Have eny of you worked on steering box rebuilding. Bottom seal can be bought. But mine has the 1/4 turn shuffle's going tryed tighten adjuster not much differnt . going to try the full left turn tighten and back off to night. tie Rod ends not worn that bad.Got to be the box 60,000 miles on it ? eny hints Very Welcom Thanks. Update found a place in San Antonio . tx that rebuilds them going to pull box out and try them. Called Stangers site Or Precision Products ph 210-687-1313
  4. 1968pickup
    1968pickup
    from ND
  5. Hellfish
    Hellfish
    That would take a lot of machine work since the 144/170/200 intakes are part of the head. I know it can be done, and there's an article about converting the small intake in the Ford 6 club book, but I would think that after all the time and money involved to add a little power to the small 6, you could've just added a 240/300/289/302 for less
  6. econovanman
    econovanman
    from yakima wa
    Actually you might have to change the bell housing they changed the bolt pattern in 68. Also you will have to weld some ears on the trans so the bellhousing will fit if you have the type 9 trans
    Correction! According to classic inlines and the ford six fourm, ford changed the bellhousing bolt configuration in the later months of 66. Not 68 like i previously stated
  7. econovanman
    econovanman
    from yakima wa
    Also you will have to use the 144 / 170 clutch disk and the 200 pressure plate. I made a pilot bearing on a lathe
    Out of oilite bronze bearing stock. Because i couldnt find the propper size.
  8. Straight Axle Steve
    Straight Axle Steve
    I just pulled a 144 from 1961 and replaced it with a 170 from a 1966. Didn't have any of these issues. Whew! Glad I didn't have a 1968 engine.
  9. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
  10. olgraybeard
    olgraybeard
    Been working on it all winter next is rust repair (lots of holes)
  11. neondv8
    neondv8
    new to this forum, here's what i got going on in wa.pic on the left is how it look now.
  12. Church
    Church
    from South Bay
    Friend is looking for a 5 window econo truck if anyone knows anyone. Pm me.
  13. Hogride
    Hogride
    http://hogrides[​IMG] picsGot my Econoblaster out for a little summer fun. Dont pay attn to camera date MY friend has not set the clock on his vhs player ether Ha Ha !
  14. chainsaw
    chainsaw
    Nice, what size tires and rims ?
  15. go-twichy
    go-twichy
    that's a sharp little truck ^
  16. j.r. Nice
    j.r. Nice
    Simply, the difference between the C6 2wd and 4wd is the tailshaft and the extension housing. Then the transfer case bolts to that. I doubt a 4wd version would help at all.
    Are you putting the engine in the bed or near stock location?
    I saw one (yellow ?) with a 429 in Akron/Canton area(?). I thought a SBF was stuffin'
  17. greensheads
    greensheads
    Its going to have to be set back some, no way a 460 will fit between the seats...I'm thinking a shorty powerglide might be the only thing that will be really short and take the abuse. Should be a wicked ride ... going to need some major frame beefing as well...
  18. greensheads
    greensheads
    Sounds fun. I am going the 347 stroked 302 and AOD route. I will be posting my progress as well. I have been trying to think of the best way to add a roll bar. I don't really want bars going out the back of the cab, and I don't want it to be too obstructive or noticeable in the cab....
  19. thunderbirdesq
    thunderbirdesq
    all weather vehicle...
  20. econolineherb
    econolineherb
    Hi . There are two Great Econoline groups on the net . oldeconolines and the group i'm in econosrus . These are a bunch of Econoheads that eat , talk and bleed Econo . Check them out and ask away .
    Herb in Fl.
  21. greensheads
    greensheads
    Yep, I am a member of oldeconolines, the guys on those groups really know their stuff. http://vintage-vans.forumotion.com/ is a great place as well....
    I am trying to make my econo look as stock as possible save a few minor things. Similar to the above pic. I plan on driving it a lot, so I want at least OK mileage, thats why I am going with an overdrive trans. I plan on dressing the engine to look like a falcon sprint 260 engine.
  22. Hogride
    Hogride
    I Have a friend. Yes I Know. No Pic not true ! Ha Ha Thats Doing the very same thing to his that your doing 347 & C5 trans
  23. Flootiebuell
    Flootiebuell
    Before....and......After
  24. chainsaw
    chainsaw
    Just bought this one. It was for sale in the classifieds about a year ago. If anyone knows the builder please pm me. I want to know if its paint or primer. ImageUploadedByTJJ1368240800.855721.jpg
  25. mike hohnstein
    mike hohnstein
    from wisconsin
    This little truck was in the shop recently, very impressive build. Engine set back a good bit, probably lift the left front wheel on launch if you tried real hard. SBF w/a C-4, 4 link rear suspension.
  26. Hogride
    Hogride
    Man that truck is Nice !
  27. AndrewnTX
    AndrewnTX
    from Plano, TX
    Just put this aluminum radiator in my '61, along w/ an electric fan. The brass radiator that was in yet has a very minor pinhole that was starting to leak, if anyone needs a brass radiator, come get it. Whoever put the truck together had the bottom outlet specially put on as you see in the pic.
  28. tiki_spike
    tiki_spike
    Hey AndrewnTX, what did you use for an electric fan? I've been looking into them too but haven't decided on a brand yet. Thanks.
  29. AndrewnTX
    AndrewnTX
    from Plano, TX
    I went the easy route at the local parts store.
    Used a Hayden 3690 from OReilly's, a 14" fan it measures about 15" or so overall, so it covers the core pretty well.
    http://www.oreillyauto.com/site/c/d...35899&ck=Search_3690_1335899_527&keyword=3690
    Along with the fan, Hayden's 3647 fan controller and relay kit was installed; you can adjust the fan's kick on temp 160d-210d via a small dial on the unit, the relay, temperature probe and fuse are all part of the kit.
    http://www.oreillyauto.com/site/c/d...35899&ck=Search_3647_1335899_527&keyword=3647
  30. 2dr_sedan
    2dr_sedan
    Another awesome HAMB thread!
