64 impala guys, question for ya
Discussion in 'The Hokey Ass Message Board' started by Blown 61, May 12, 2013.
  1. Blown 61
    Blown 61
    I have a friend with one with a three on the tree and all the shift linkage is worn out, where can I find replacement parts? also is there a two piece driveshaft? if so would a bad bearing at the split cause a vibration? one more thing where should the timing be? 283 cid
    Thanks!
  2. bobwop
    bobwop
    from Arley, AL
    yup, a bad bearing could be the culprit.
    don't know about the linkage. There are some bushings that could be worn
  3. Timing depends on a lot of variables. Start at 18 btdc and go from there.
  4. Blown 61
    Blown 61
    There are bushings and a pivot on the frame is worn out, wondering if there is a place I could get all new stuff from??
  5. Check with the 59-64 Impala clubs I bet they can help ya!
  6. Blown 61
    Blown 61
    Where do I find them???
  7. brigrat
    brigrat
    from Wa.St.
    Impala Bob's is a start.
    Timing?
    Disconnect & plug the vacuum line from carb to vacuum canister on dizzy, I start at 6-8 BTDC, their are variables as mentioned........................
  8. 61 chevy
    61 chevy
    google 1964 impala, you can buy ever thing for them, also ebay
  9. I Drag
    I Drag
    Yes it is a 2-piece driveshaft. A drivetrain vibration on these cars is likely the Carrier Bearing. While replacing it, also do all 3 (!) u-joints. Cl***ic Industries is one source.
  10. Gizzy
    Gizzy
    from N.W,Ohio
    I've got a 64 belair, bought a lot from Ecklers.Just google it.
  11. Lutty's out of PA. They have tons of Impala parts. I used them for my 1963 Impala SS resto. Also there is Hubbards. Both are vendors at Spring and Fall Carlisle. A good national club is VCCA; Vintage Chevorlet Culb of Amreica. Good luck.my .02.
  12. bobwop
    bobwop
    from Arley, AL
    but tell me this...who has the parts necessary to rebuild the three speed linkage?
  13. Google?
  14. 327Eric
    327Eric
  15. rag-4
    rag-4
    try Cl***ic Industries or CARS1
  16. cooljunk
    cooljunk
  17. bobss396
    bobss396
    Chevy dealers used to stock a GM kit with everything needed to rebuild the column shift. It was a big job, the last one I did was on a 3-on-the-tree Chevy truck and the whole column had to come out.
    I'm sure one of the sources above has it for the '64.
    Bob
  18. biscaynes
    biscaynes
    do yourself a favour and buy the poly hanger bearing
  19. rlowrod
    rlowrod
    from Corona Ca
    best replacements parts around, www.truckandcarshop.com
    there located in southern California and have on-line catalogs, mail order or walk in service.
    I use them all the time for my projects.
    They should be able to help with the linkage but the bearing can be purchased from pepboys, o'rielly's or most any other auto parts store.
    :D hope that helps.
