Projects My 1950 Chevy Styleline DeLuxe
Discussion in 'The Hokey Ass Message Board' started by LeftCoastErik, May 7, 2011.
  1. 1950heavymetal
    1950heavymetal
    Awesome build! The front bumper update is killer!!
  2. Marten
    Marten
    Nice front..damn!
  3. LeftCoastErik
    LeftCoastErik
    Sneak peek of the paint process. Jambs are done
    Sent from my DROID RAZR using Tapatalk 2
  4. Thommyknocker
    Thommyknocker
    from Colorado
    I foresee you and 4k grit quickly becoming enemies:D
    Looking good, don't let me beat ya :p
  5. LeftCoastErik
    LeftCoastErik
    Underside of the hood. turned out way nicer than I figured. Starting to go back together
  6. 66slabside
    66slabside
    Lookin' killer man Can't wait to see the final product Been subscribed for a while now.
  7. BadLuck
    BadLuck
    oooOOOOooooooo :D YES!!!
  8. M.Edell
    M.Edell
    It amazing what you can do with Krylon...lol...
  9. LeftCoastErik
    LeftCoastErik
    Hell yeah!! Plastikote is my friend. that and some splatter paint and I should be good right?
  10. M.Edell
    M.Edell
    Dont forget some VHT! Zolotone Rules! just make sure you clear it after...
  11. chaddilac
    chaddilac
    Oh wow!! that bottom of that hood looks killer!!!
  12. 1 KooL "MoFo"
    1 KooL "MoFo"
    Front and rear bumpers look supper clean Great Job !!
  13. BadLuck
    BadLuck
  14. LeftCoastErik
    LeftCoastErik
    24 days until we leave for Santa Maria... this is what the car looks like today. I got the ac all set up. Tomorrow we Fab the splash pan. Then back to Kustoms By Jennings to complete the paint. I dropped the front seat and door panels at the upholstery shop today too. Gonna be a thrash but we're going either way
  15. LeftCoastErik
    LeftCoastErik
    Here's
    Today's progress.. new splash panel center and new ends. Took all day but Curt at Hill's Rod and custom is the man
  16. LeftCoastErik
    LeftCoastErik
    Today we finished up the pan and install. Then I drug it back to Kustoms By Jennings where I got to take it all apart so the pan can get body worked. I did get the belts on the ac system/ alternator so we are charging again. Dropped the ac lines off also to be crimped. Hard to say if I'll get the bumpers back in time but I should be cool driving down..
  17. LeftCoastErik
    LeftCoastErik
    Muddin up the pan and satin black for the rad support. Found a guy that can do the bumpers by our deadline. 20 days to gogo
  18. cbmkr56
    cbmkr56
    from Kansas
    I really looks nice, I am currently working on my 50 fleetline. I have a question about the S10 trans, do you know which model you used and how is it holding up. My 235 is very highly modified and splitting bellhousings , i am a little hesitant to use the s10 5 speed not sure if it is strong enough.
  19. LeftCoastErik
    LeftCoastErik
    I can't imagine a 235 with enough poop to break bell housings. Any chance you have bad mounts or something? Either way a t5 from a 2wd s10 or small blazer is what you want. V6 ideally. They are pretty tough and can handle mild small blocks so they should be pretty indestructible behind a 235
  20. cbmkr56
    cbmkr56
    from Kansas
    No bad mounts , it was built in the mid 70's, and ran very well. I went thru several muncie's and tore up a T10 ( Twisted the tail shaft off) and ended up running a muncie Rock crusher for the last years it was on the road. We parked the car in 79 to take care of our business and other things. Just started restoring the care this winter and was changing the trans out and noticed the bell housing split up the middle. I tied the engine down pretty solid back then as it was always breaking mounts and twisting things around. I currently have a T5 from an 85 V6 camaro and all the local guys that know the car keep saying not to use it , it just will not last if i run it hard. It made RPm in the mid 5600-6000 range and was a lot of fun to drive. The biggest problem then was throwing the fins of the generator and cutting the belt
  21. LeftCoastErik
    LeftCoastErik
    Wow sounds like some motor! I know the gear sets in the t5 are weaker than that rock crusher. Don't know about the case but I doubt Itll hold up
  22. LeftCoastErik
    LeftCoastErik
    Dropped these with Randy at Robinson's Chrome on Sunday morning. Now they look like this. A little more TLC around the exhaust ports and they are ready for dippin and copper
  23. LeftCoastErik
    LeftCoastErik
    15 days..today we laid out scallops.. yeehah
  24. LeftCoastErik
    LeftCoastErik
    Its out of the booth! Huge thanks to Brian and Kirk Jennings for all the. Hard work![​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my DROID RAZR HD using Tapatalk 2
  25. Styleliner
    Styleliner
    Awesome paint.... More coming?
  26. LeftCoastErik
    LeftCoastErik
    More what? Pics? I will take more as it gets polished, but then its off to the upholstery shop for a few days so they can finish it up.
  27. YES! Less is More....Great work Eric.....I love this car......:)
  28. Squids50
    Squids50
    from cal
    Looks *****en Eric, I hope to have mine in paint soon also. Have you shown pics to the prior owner. He is going to flip if he sees it.
  29. LeftCoastErik
    LeftCoastErik
    1200,1500,2500,3000...Brian is cutting and buffing. I was told NOT to touch any sandpaper....
  30. BadLuck
    BadLuck
    daaAAmn.. those scallops set that whole car off perfect! nice restraint... im a big believer in the whole less is more.. absolutely perfect.. absolutely beautiful.. right on Erik.. stoked for you buddy!
