Can i spray this type of paint
Discussion in 'The Hokey Ass Message Board' started by johnnyvees, May 13, 2013.
  1. johnnyvees
    johnnyvees
    from sunland ca
    Hey all
    i need some help i have a gallon of Rust-oleum truck bed coating paint it is a texture finish and i want to know if anyone has ever used a spray gun to spray there bed or other parts i called Rust-oleum and they said that they have never tried it but that they do sell it in spray cans. so if anyone has used a spray gun let me know.
    thanks,
  2. FenixSpeedShop
    FenixSpeedShop
    You can spray it, you just need the correct sized fluid tip for the gun. If its the one Im thinking about you will need a HUGE tip for it.
  3. Ford blue blood
    Ford blue blood
    Yup, try an undercoating gun....
  4. chevyburb
    chevyburb
    Yea, we sprayed bed liner on the underside of the fenders on Faye using a "Shoots" (wrong spelling) gun for undercoating.
  5. lht
    lht
    sholtz gun
  6. K13
    K13
  7. blue 49
    blue 49
    from Iowa
    I sprayed Zolotone bed coating through a cheapy siphon gun by putting a tee in the air line and pressurizing the pot at the vent fitting, through a regulator set at about 5 psi.
    Blue
  8. da34guy
    da34guy
  9. kracker36
    kracker36
    I coated the underside of my 62 fairlane with Herculiner. I used a normal sandblasting gun for a cabinet style set up ( siphon fed ). I just removed the ceramic insert and it worked like a charm. Cheap and easy.
  10. johnnyvees
    johnnyvees
    from sunland ca
    thanks for all the help guys, so now its time to buy a schutz gun.
    thanks again,
