Features Econoline Madness Who's got one?
Discussion in 'The Hokey Ass Message Board' started by kornfedlifer, Apr 25, 2007.
  1. Hellfish
    Hellfish
    I used a SPAL in mine.
    If that engine was set back, it would probably be sitting in the bed.
  2. tiki_spike
    tiki_spike
    Cool, thanks. I need to put one in too, especially with summer coming quick!
  3. greensheads
    greensheads
  4. Hogride
    Hogride
    Thanks I Needed That :D just looking at motor and trans are 65 inch long Im thinking I will just have a short drive shaft and it will fit fine . going to cut floor out to the frame and wing out the bottem half of dog box going to set motor a little back and down a few inchs I think it will be fine that way. Need some HD leaf springs for front this motor is 730 lb geez big chunky monkey for sure. I think small blocks about 550 lb
  5. Zettle Bros.
    Zettle Bros.
    Anyone on this thread have a early (1961 to 1967) steering box. Found that the one on the GTO is worn out. Thanks.
  6. unclescooby
    unclescooby
    from indy
    I just bought this one but it's got a flipped front axle. Anyone got a dropped axle that they are happy with and RECOMMEND?
    droppedstepside likes this.
  7. Hogride
    Hogride
    STEERING REBUILD ! precision Products 24165 IH-10 West. Suite 217-282. San Antonio . Texas 78257-1159 Or StangersSite.Com 210-687-1313 PH will fix ya right up On Steering Box Rebuild
  8. 65EconoPU
    65EconoPU
    Here's mine, a 65 Spring Special. Just put it back on the road after 10 long years. I'm in shake down mode for a while then paint and trim.
  9. AndrewnTX
    AndrewnTX
    from Plano, TX
    Lookin good, that interior especially the seats look great!!
  10. AndrewnTX
    AndrewnTX
    from Plano, TX
    I'm looking for axle bump stops, these pop into holders on the frame. My front ones are gone and big bumps hit hard. I check Mac's, and parts places, no luck. Anyone got a tip where to find some?
  11. 65EconoPU
    65EconoPU
    Thanks, the seats came from JEG's. They were cheaper than rebuilding my old ones. Speedway has the same seats but shipping was more.
  12. Hellfish
    Hellfish
    I found similar ones at Summit. Unless you're doing a restoration, no one will care if your bump stops are "correct".
  13. unclescooby
    unclescooby
    from indy
    Got new brakes and fuel pump on yesterday. Gotta flip the front axle back over and then the new kidmobile will be active.
  14. econolineherb
    econolineherb
    If your going to use that radiator the brackets are on wrong .
  15. econolineherb
    econolineherb
    Hi . Can you send me pics of that lowered axle ?
    Herb in Fl.
  16. unclescooby
    unclescooby
    from indy
    anybody know where I can get a new fuel tank? Didn't see one at Mac's.
  17. JCShiels
    JCShiels
    In the late 80's I swapped the 170 in my 1964 Falcon Club Wagon for a 200 out of a Fairmont. The 200 had both the early and later bolt patterns on the back of the block, I think it was a 1978 Fairmont. It was a bolt in swap, I used the van's original bellhousing, flywheel, mounts etc. The only noticeable difference was the waterpump length, but the fan still cleared the radiator so I kept the Fairmont pump rather than change to the shorter pump.
  18. Hellfish
    Hellfish
    You can't get an Econoline specific one, but you can get a 15 gal or 20 gal 65-70 Mustang tank brand new for $100 and teh Econo gauge will read the sender. You will have to move the inlet though
  19. j.r. Nice
    j.r. Nice
    I swapped in a '69 Mustang tank that I bought off Ebay. IIRC about $125 with sender. 20 gallons. I made my own straps out of galvanized.
    As Hellfish mentioned, filler tube needs moved. As far as the vent tube and such, heat it up (AFTER FUMES ARE DEALTH WITH!!!) and melt the solder and pull 'em out.
  20. johnnybentwrench
    johnnybentwrench
    Hi Everyone, I got real lucky and was contacted by the owner and asked if I wanted to buy an all original 1964 E100. The truck has been stored in a garage its entire life. 90,000 miles. I will need a tai gate this has a lift gate on it. The truck was used by a Japanese Gardener and not driven in the rain. it really is clean and rust free. Really rust free
  21. unclescooby
    unclescooby
    from indy
    I was able to get a gas tank from HAMB'er Skip396. :) I just got the radiator redone and it was $372!!! Ouch. Got some Fenton Hawks from another HAMB'er and should be on the road by next week.
  22. Hellfish
    Hellfish
    You got ripped off, Scoob! I bought a brand new 6 cyl Mustang radiator for about $100 and all I had to do to make it fit was flip the mounts.
  23. econolineherb
    econolineherb
    Hi . Got my 240 radiator recored for $ 300. Van won't get hotter than 170 moving and 180 in traffic
    Herb in Fl.
  24. unclescooby
    unclescooby
    from indy
    agreed. I think I took in the poopshoot on this one. Admittedly, after not finding new ones available, I just dropped it off and didn't even ask about the price. Got sticker shock when I went to pick it up. Oh well...chalk it up to joy tax. I'm gonna be cruising in short order here.
  25. Vendome
    Vendome
    That little truck is just plain sweet! Congrats!
  26. econolineherb
    econolineherb
    Hi . That's not bad . The first shop i went to wanted $ 400. i said that will buy alot of stop leak .
  27. johnnybentwrench
    johnnybentwrench
    Hi Everyone, I am changing out my points set.I do not have a manual yet. Can anyone tell me the gap? 1964 Econoline pickup 170 engine
    got them
  28. econolineherb
    econolineherb
    Hi . I gap mine with a match book cover or 0.16 . Spark plugs with a 1964 silver dime or 0.35 .
    Herb in super wet Fl.
  29. johnnybentwrench
    johnnybentwrench
    Thanks. I think the cap I got is wrong? The rotor has machined grooves in the cap and left brass shavings in the distributor.
  30. econolineherb
    econolineherb
    Hi . Make sure the cap is the right one . There is one that in made alittle smaller and will bust up rotors and if the metal pieces fall in the points will short everything out .
    Herb in Fl.
