Best 4 barrel carb for stock 390fe?
Discussion in 'The Hokey Ass Message Board' started by kingdesgn, May 13, 2013.
  1. kingdesgn
    kingdesgn
    All carbs besides Autolite 4100 .... that's what I have on there now.
  2. Poesrodandcustom
    Poesrodandcustom
    from Kentucky
    600cfm Holley or Edel would be fine. I prefer the Holley myself.
  3. 57Custom300
    57Custom300
    from Arizona
    As mentioned the 650 Holley is a good choice. Although the 4100 wont perform as good as the Holley it wont give you as much trouble as the Holley. My .02
  4. carbking
    carbking
    Carter 4759s (manual choke).
    Carter 9627s (electric choke).
    Carter 9637s (electric choke and EGR port which can be plugged).
    All of the above are 625 CFM AFB carbs.
    For the record, I run two of the 4759s (modified) on my modified 390.
    Jon.
  5. kingdesgn
    kingdesgn
    ttt
  6. KandN Kustoms
    KandN Kustoms
    I got a 650 edelbrock on mine and it runs just fine for the last 7 or so years.
  7. rocketsled59
    rocketsled59
    Edelbrock for the street Foolproof. Not built to leak. Likea Holley
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    There is no "best" carb for that motor, all you will get when asking this question is what some of our personal favorites are. Some are going to say Edelbrock, some will say Holley, some will say Rochester, and others will say put back the carb that came on it. It all boils down to what each of us have had good luck with.
    Pick one in about the 600-650 cfm range and you will be fine.
    Don
    Tommyslowlow likes this.
  9. rocketsled59
    rocketsled59
    Dons answer gets my vote
    MarkusOTK likes this.
  10. Well said Don! And I agree, it is easy to over carb CFM, the forgotten part of the choice is what RPM will it be running at? Cruiser 600 and deep gears, loose converter or stick, big cam, then a 750 or so. Good luck...
  11. I also agree with Don & oldguard. I had a motorcraft 600 cfm in my stock '62 Thunderbird. I had nothing but problems with it. The last straw was when it started leaking gas out of one of the seals and began to catch fire. Having the car as a daily driver, I needed something less explosive and better preforming then that. I bought a Edelbrock 650 cfm with manual chock because I got a really good deal on it and needed something dependable. I never had a problem with it the hold time I owned the car. Good luck kingdesgn
  12. mikhett
    mikhett
    from jackson nj
    I put a 600cfm holley 1850 list w/electric choke on my 62 galaxie xl 390FE.It goes down the interstate 3 times a week at 70mph no problems
