Ever see Stromberg 97 fittings like this?
Discussion in 'The Hokey Ass Message Board' started by Groovybaby6, May 14, 2013.
  1. Groovybaby6
    Groovybaby6
    from Denver
    Looks like an ancient hose barb style they don't make anymore.
    I don't know who used to make these but, they have the number 4305 on them.
  2. paleot
    paleot
    from louisiana
    Common fitting still made today, I have a bin full of them Kar products co supplyed them.
    Tony
  3. pinkynoegg
    pinkynoegg
    looks like the male fitting of an air chuck
  4. Pete1
    Pete1
    from Wa.
    Common fitting available at most hose and fitting supply places.
  5. dickster27
    dickster27
    from Texas
    That's the front side. The rear will be a bit harder to find. It is a 5/16"-45@ SAE flare
  6. chop32
    chop32
    Ive found these in the past at CARQUEST.
  7. OHV DeLuxe
    OHV DeLuxe
    from Norway
  8. 32-3 WINDOW
    32-3 WINDOW
    from utah
    weatherhead br*** fitting , sold also thru napa
  9. santa28a
    santa28a
    These fittings have a deeper threaded part with a tapered seat. Same as used on the Lucas CAV diesel fuel filter ***emblies with a gl*** bowl.
  10. Groovybaby6
    Groovybaby6
    from Denver
    I guess you can't tell in the pic but this fitting is for 1/4" hose.
    Stromberg only makes a one size fits all 5/16 & 3/8 size. That works fine but if you have a Model T or Model A hot rod, 3/8 hose looks enormous!
    I took it out of the carb and put some 1/4 clear red hose on it, take a look.
  11. carbking
    carbking
    As I have posted before, the so-called "Stromberg 97" is the Ford variant of the conventional Stromberg EE-1.
    This fact is applicable to this thread in that there are a number of different fuel valves that will work with the Stromberg EE-1 that have more conventional outer threads than the one used by Ford. Just from memory, in additional to the Ford version, there are at least: 1/8 male pipe, 1/8 female pipe, male tube, female inverted flare, and one made for ethanol with a much larger orifice that has the hose barb as a part of the fuel fitting.
    Personally, I prefer metal lines, but to each his/her own.
    Jon.
  12. Coupe Deluxe
    Coupe Deluxe
    I had the same type of fittings on a pair of 97's I'm using on one of my cars. Removed them and used compression style fittings and ran 1/8 metal line. Works and looks good.
  13. Pete1
    Pete1
    from Wa.
    They also have fittings with a flare that will take a 3/8 stainless/teflon braided line.
    Both straight and 90 deg.
