Gasser/Street Freak front axle pics.
Discussion in 'The Hokey Ass Message Board' started by k-member, Feb 3, 2008.
  1. papajohn
    papajohn
  2. andy55
    andy55
    Is that a Hemi in there?
  3. Sgt._Grumpy
    Sgt._Grumpy
    My 65 Nova SS during construction
    droppedstepside likes this.
  4. Red71
    Red71
    from Illi-noise
    Bringing it back around again.
    some good info here .... I think?
    found some stuff I can use,thought some else might.
  5. blue 49
    blue 49
    from Iowa
    Here's a build pic of my Henry J. Still a long way to go.
    Blue
  6. BCCHOPIT
    BCCHOPIT
    [​IMG][​IMG]
    A custom 2.5" .312 wall axle I made the other year
    [​IMG][​IMG]
  7. 1971BB427
    1971BB427
    from Oregon
    My '46 Austin, with 36" center kingpin tube axle. Corvair steering box.
  8. Moon Rocket
    Moon Rocket
    from GA
    This axel has only been in for fifty years so the verdict is still out I guess.
  9. 1971BB427
    1971BB427
    from Oregon
    And here's the setup I'm building presently. Econoline axle in a early Falcon:
  10. Baron
    Baron
    3 years later and still working perfect.
  11. SmokinBill
    SmokinBill
    3 years and 8k street miles so far.
  12. henryj1951
    henryj1951
    from USA
    did one in 68 ...
    :cool:
  13. Love that pic Moon Rocket, tell us more!
  14. marks73turbota
    marks73turbota
    Showed the start of my Catalina back in 2011. Still building it but much, much, more done. Frame and suspension all done. Motor built and together but yet to fire it. Trailered it to a local Pontiac Car show event last weekend. I got the "Best Engine" award even though mine was the only engine there that did not run, LOL.
    This is the finished front end. I used a 525 Saginaw steering box with a cross steer drag link ahead of the axle. I used the original Chevy rear tie rod mouts behind the axle to retain the original Ackerman and use the axle to protect the tie rod from road debris. Made all rods with 5\8ths rod ends. I may change to a power steering system later if I need it. If I can find room on the motor to add the pump and brackets.
    The car at the show with the award.
    Getting closer to drivable but a ways to go yet.
    Mark L
  15. Baron
    Baron
    Looks great. Come along ways from the earlier posts / pics. Plenty of power with the twin Turbos I'm sure ! Congrats on the award.
  16. Everytime I see that Pontiac I am impressed, way out of the box and so cool! You go! And keep posting progress, please... :D
  17. mopar210
    mopar210
    our little "rumbler" getting close to done !
      144.5 KB
      147.1 KB
      146.7 KB
  18. GasserDude
    GasserDude
    from Arkansas
    I realize its not for everyone but mine works well with coil overs. You can't see it from this shot very well but I used hair pins instead of 4 bars. No complaints the cars drives and handles like a dream, been 143 so far and looking forward to more.
    droppedstepside and 91kustom like this.
  19. marks73turbota
    marks73turbota
    Thank you Baron and Oldguard for your comments. Long ways to go but getting there. As I'm get closer to running the motor I have to force my self to take my time. I was really glad to get the ch***is all done. It was a big part of the build to get completed. Right now working out how to get the water from the rear radiator to the front and back. I have a tight spot under the seat mounts between the ladder bar crossmember and the bottom of the floor to over come. The I can get real close to running the motor.
    G***erDude. I really like the looks of the hairpins and the coil overs. Probably saves a few pounds over the leaf springs too. Are you using a front panhard bar or something else to locate the axle? Mark L
  20. MannyK
    MannyK
    from NYC
    These are some great pics!
  21. GasserDude
    GasserDude
    from Arkansas
    marks73turbota. here's a couple shots of the panhard and shocks. kinda hard to see but it's mounted right behind the axle so it's not so visible. it saves a few pounds and the adjustable shocks don't hurt either.
    [​IMG][​IMG]
  22. marks73turbota
    marks73turbota
    Nice nice set up. I like the way you hid the panhard bar and the pins with coil overs make it look so clean. I would like to go to a true straight axle sometime in the future. The truck axle I'm using is so bulky looking and it restricts how wide it can go. For my tastes I'd like to have the axle a little wider to place the tires out a little farther. Right now I'm using 1/4 inch spacers and offset 6 inch rims. Also the tires are a little bulky too. But because the car is so "BULKY" it is not too bad looking (to me anyway). Your '55 is just so "right" looking, love it. I've always loved the g***ers and the full bodied altereds, but I'm a loving the early '50's Pontiacs. I had to go with a Pontiac. The first "Street G***er" I ever saw was a '57 Chevy with a Mopar 416 or 440 set way back into the firewall, back around 1967. I was a year away from my license and it has stuck with me all these years. Matter of fact. It was pretty much the same color as your '55, maybe a little bit deeper blue. It's the car that hooked me because I had never been to the strip yet. Man I love your car. Mark L
  23. marks73turbota
    marks73turbota
    This is a better shot of the front of my car.
    One of the rear.
    Mark L
  24. I like it! What axle are you running Mark? I have a Sids "undropped" and drilled '47-'55 Chevy pick up axle for my '42 Chevy g***er.
  25. marks73turbota
    marks73turbota
    Mine is a '57 Chevy pick up with stock dimentions. Did you have an axle that you sent to have straightened or did you buy it that way? I'm wondering because I would like to know how much wider the axles comes out to when it is straightened. If I had mine straightened it might just give me enough additional width that I would not need to change to a different one?? I also have the complete Speedway disc changeover so I would like to keep the axle. I don't think the guys that make the custom axles use the the king pins etc to keep my disc conversion. I don't want my front too high though and straightening it may get me up too high. I like the drilled axle too. Maybe I'll try it one day. What diameter are the holes?
    Do you have any pics of the '42? I had originally intended to use a '40 Olds coupe for my g***er but I ended up trading the '40 body and another body for this totally rust free '63. I just had to Street Freak the '63.
    Mark L
  26. Sid can stretch them some and I will measure the holes tonight. He also straighten or drop them and he magnafluxes them.
    www.droppedaxles.com
    He is here on the HAMB
  27. seb fontana
    seb fontana
    from ct
    Damn, I didn't know he could do that!! And to think about it why not? Or even make them wider with same drop or even narrow some..I gotta hit him up for the process pics he promised me..Ought to be interesting..
  28. seb fontana
    seb fontana
    from ct
    Mark, you got a big car and I think it is pretty proporsionate as it sits, height is good..I would not increase the front tread or change tire size, that looks good too...You have a lot of black in the front end, lot of space between the splash sheild and the spring shackles..Some different colors to break up the black m*** or how bout a lightened front bumper? Thinned some [top to bottom] with a few [or a bunch] holes, formed lip ones would be neat, with or with out park lights [or maybe some leds set in from a slot opening so they would only be seen when on] and painted to match the car [for cost] but I think it would look slick chromed...Or something like a 70-73 mustang front bumper, probably not wide enough but thin enough....
  29. Prostreetgasser
    Prostreetgasser
    I'll post some pictures of the progress on my "55".
