new clutch... pilot bearing, or solid brass bushing?
Discussion in 'The Hokey Ass Message Board' started by 1950kale, May 17, 2013.
  1. 1950kale
    1950kale
    hi everyone, i'm putting in my clutch on my 91 chevy 350 and was wondering if i should use the pilot bearing or a solid bronze/br*** bushing, iv heard good and bad about both. i have both, so thats not an issue, but iv heard that the bearing will wear out faster & chew up the input shaft, but iv also heard the solid br*** one may seize up if clutch is depressed to long while in gear. does anybody have any recommendations?
    thanks in advance
    Kalen
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Had several bearings die but never a issue with the br*** bush in the last 53 years.
  3. black 62
    black 62
    from arkansas
    those bearings make no sense ...
  4. philjafo
    philjafo
    from right here
    I always use the bushing with a little high temp molybdenum grease.
  5. JC Sparks
    JC Sparks
    from Ohio
    The material is oil impregnated bronze alloy. JC
  6. gimpyshotrods
    gimpyshotrods
  7. ttpete
    ttpete
    from SE MI
    Using a needle roller bearing requires that the nose of the input shaft is hardened, otherwise it will brinnell and wear. I've never had a problem with an oilite bushing.
  8. Standard gas&oil
    Standard gas&oil
    from USA #1
    I just replaced a roller type and went back to a solid bronze bushing. Remember when a roller bearing goes to hell it will ruin the input shaft on the transmission and it was hell to remove and could not get it to pop out using grease I finally tried bread and got the bad roller bearing to finally pop out.
  9. BRENT
    BRENT
    I have to replace the bearing on my 49 ford T5 conversion. I went with a bearing over the bushing and now after driving the car for a while it heats up and is hard to shift. My guess is that motor warms up and is turning the ****** and its not letting me shift. I shut the car off, shifts fine (motor stopped). Also works fine for about a half hour then starts to stick. Everything else worked out great on the conversion, I just made a bad decision.
    My .02 cents, Please run a bushing! LOL.
  10. I'm using the solid bushing & Zoom clutch ***y I purchased thru Summit with my M-21 ****** behind my 350. Had to replace the throw-out bearing after a very short time due to the slave cylinder actuating rod was not lined up correctly with the fork. The action of the fork caused the bearing to fail prematurely. I corrected the alignment with the slave cylinder, replaced the throw-out bearing with a good Hayes one and kept the solid bushing. So far no issues.
    I'd go with the solid bushing.
  11. Motomike43
    Motomike43
    Bushing only. No maintenance. They last 2 clutch jobs or more...
  12. ttpete
    ttpete
    from SE MI
    Bread makes a mess. Soak paper towels in water and pack them behind the bearing, then punch it out. No muss, no fuss.
  13. snaptwo
    snaptwo
    Not having any oilite bronze on hand , I turned a bushing out of some 660 bronze just to get a clutch job out of the shop . Big mistake on my part as that ****er locked up in about 20 minutes use !Even though we had packed the whole recess full of grease. Oilite-Oilite-Oilite !!
  14. pasadenahotrod
    pasadenahotrod
    from Texas
    Interesting that Ford used flywheel bearings for decades, GM used bushings for just as long and they worked fine too.
  15. bobss396
    bobss396
    Yup, look up oilite bronze, that's what they're made of. Odd as it seems, they're mostly copper.
    Bob
  16. stlouisgasser
    stlouisgasser
    I like the primitive bushing over the bearing also but I've always wondered why I must be the only person on the planet that has to keep an adjustable reamer (pre-set, just for this job!) in my tool box to slightly shave the inner diameter of the bushing after it shrinks from being installed in the back of the crankshaft.
  17. tjet
    tjet
    I used a Napa bronze bushing on my vette. The inner diameter was too small & the input shaft became stuck in the bushing. I should have gotten a clue that something was amiss when I needed to draw in the trans with the bolts.
    I ended up getting an OEM GM truck bushing with the rollers. No issues, 12 years. The only reason I went with a roller is that GM no longer makes / sells the solid one.
  18. CGkidd
    CGkidd
    Anyone try the new Kevlar pilot bushing?
    Sent from my DROID device using the TJJ mobile app
  19. 1950kale
    1950kale
    well thanks sooooo much for all the help, very much appreciated, & im guessing that i should probably go with the bushing, haha well thanks alot guys
    kale
  20. buckd
    buckd
    Without the proper tool to install a bearing , 1/2 the time it will distort. that's why so many failures occur. I'd go with the bushing if it lasts longer than the disc......... mission accomplished!!! Buckd
