Projects 36-taildragger.....Made in Sweden
Discussion in 'Traditional Customs' started by Kenneth31coupe, Mar 17, 2013.
  1. EliteS&C
    EliteS&C
    Great work so far! I really like your ingenuity & design work on the mounts! much nicer than most I've seen! Subscribed!
  2. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks.
    Thanks.
    To bad the weather has been very nice here last few days so I have had to paint my house instead. Not much progress in the garage for now unless it will start raining.
  3. fleet-master
    fleet-master
    looking good Kenneth. Great job on your ch***is so far! i like the LaSalle grille very much.
    subscribed
  4. toucan
    toucan
    from sc
    keep it up kenny, gonna be a sweet ride!
  5. tbcworks.com
    tbcworks.com
    Nice looking build underway.... can't wait to see it finished!
  6. sololobo
    sololobo
    Outstanding fab work, this is going very nicely. Congrats on good taste on the project. ~sololobo~
  7. rat nasty
    rat nasty
    suscribed! awesome work looks like your headed in the right direction!
  8. lwrthnu07
    lwrthnu07
    from Gurdon, AR
    A lot of good work! Very nice build!
  9. Tnomoldw
    Tnomoldw
  10. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks a lot guys.Really encouraging words.
  11. One of my dream cars and you are really doing it some justice! Amazing fabrications skills sir;)
  12. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks a lot Mitchell
    Sneaked away from house painting this afternoon. Rain was in the air and that´s enough for me to go in the garage instead. Made some mountings for the front shocks. Finnished up the right side and now I just have to duplicate it mirror wise for the left side. Used the ends I cut off from the rear wishbones for the lower mount. I welded a sleeve on it for a sturdier application for the bolt and then welded it to the wishbone.Upper mount I made from 3/16" steel plate.
  13. Tnomoldw
    Tnomoldw
    :)Very nice . Keep up the good work!:cool::D
  14. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Got some stuff made today. Finnished up front shock mounts and made two lowering mounts for the rear axel. Made them out off two pieces of 3/16" steel welded together in bottom and spliced as a fork in top where the axel attache.Raised the axel two inches but I believe another inch is necessary to bring the *** down where I want it.Think I´ll wait to do that untill everything is ***ambled and spring has set.Realized I have to eather c-notch the frame or make a higher kick-up for the rear axel.Think I´ll do a new kick-up, it´s a little more job but I get more space that way.
  15. 60'coupe
    60'coupe
    What a kick *** project ! Can't wait to see the body on the ch***is.
  16. Surf City
    Surf City
    Hey Kenneth
    Lovin' your work so far!
    Seems like we're both heading towards a similar goal, so it's cool to see the different approaches to some of the modifications along the way. Mine's got a slight 'hot rod' lean to it, whereas yours is pure custom. I love the way your fabricated brackets take on the look of early Ford stampings.
    Please don't put a c-notch in there - a nice sweeping re-arched rail will look a whole lot more in keeping with the rest of the build. But then, I'm pretty sure you already knew that...;)
    Bear:)
  17. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks a lot Bear.
    That´s why I like all the build threads here, to see how each and everyone tackle the work. I like what you are doing and your fabrikation skills are amazing, wish I had a shop like yours
    My goal is to make brackets and crossmembers to look like old stampings. Doesn´t means that I don´t like drilled and cnc machined parts but not on this build.Whant this one to look like it´s been made in early fifties. Have made up my plan for the rear. Gonna make a new sweeping rail and keeping the look of the stock boxing plates so only a trained eye can see what´s done.Brought home some 1/8" sheet metall from work today and gonna start on it this weekend.
  18. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Get started on the rear frame today.Rigged it up in the frame jigg again and start me***uring.Since I gonna cut the frame I decided to rise it enough so I can take away the risers between axel and wishbone.Lifted the back 4 inches me***ured from the cross member.Cut some new kick-up pieces in the pullmax and welded on some flanges to make a u-shaped piece.Got the right side tucked up and it looks good enough for me.
  19. Tnomoldw
    Tnomoldw
  20. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    So here it is, the new kick-up.If the math is correct there will bee about 4 inches of clearance now.
  21. Finnrodder
    Finnrodder
    from Finland
    Great work,man!
  22. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks guys.
  23. 53chevtrev
    53chevtrev
    from Langley BC
    Amazing craftsmanship! Love how your keeping everything looking original. Keep it up!
  24. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks Trev and the best to you and your future bride.....Kenneth.
  25. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Got the ch***i ***ambled today and rebuilt the rear crossmember again. Since I raised the rear frame the way I did the crossmember had to bee twisted some more for the spring to fit.Test fitted with running board and rear fender to see how it looks and now there´s about 1-1/2" from the outer edge of the rim up to the fenderskirt .When body and everything is ***embled on the car there´s hopefully will bee about an 1/2" and still have about 4 Inches of travell between axel an frame.Also made some bungs for the shocks and tucked them up.Now it´s not very long untill its time to set it down on wheels and put the body on.Can hardly wait.:)
  26. hotrodmano
    hotrodmano
    from Norway
    I think Im repeating myself here but this is truly wonderful and high quality work :cool:
  27. Flake32
    Flake32
    Ser riktigt bra ut, och jag ser fram emot att se den färdig
    Bosse
  28. Rpmrex
    Rpmrex
    from Indiana
    What he said^^^^^^ Im sure!!!
    Love it!!!
  29. Tnomoldw
    Tnomoldw
    :)N0 doubt about it it's good stuff !:D
  30. prefect20
    prefect20
    from scotland
    Excellent work, and nice to see you're not just buying parts from catalogues
