Quick question. Will a 28/29 model A speedometer/ cluster ***embly fit a 1931 model a? Are the gas tanks the same? Mounting the same? Posted from the TJJ App for iPhone & iPad
Also was there a speedo that read kilometers in 1928-31 A's? In Canada? I saw one once I think..... Posted from the TJJ App for iPhone & iPad
28 thru early 30 speedometers are oval. 31 speedos are round. there is quite a bit of difference in the instument cluster size so im petty sure they wouldnt interchange
Yes, I knew the earlier ones were oval etc. but wondering if actual cluster plate is different? Posted from the TJJ App for iPhone & iPad
If they were still oval in early 1930 they still bolted to the same gas tank in 30 as 31? Posted from the TJJ App for iPhone & iPad
The 28-early 30 oval speedometer dash won't fit the Late 30-31 round speedo dash tanks and vice versa.
