Model A Speedo Plate
Discussion in 'The Hokey Ass Message Board' started by KANE MCAFFER, May 18, 2013.
  1. Working Class Zero
    Working Class Zero
    Quick question. Will a 28/29 model A speedometer/ cluster ***embly fit a 1931 model a? Are the gas tanks the same? Mounting the same?
  2. Working Class Zero
    Working Class Zero
    Also was there a speedo that read kilometers in 1928-31 A's? In Canada? I saw one once I think.....
  3. vwdave30
    vwdave30
    28 thru early 30 speedometers are oval. 31 speedos are round. there is quite a bit of difference in the instument cluster size so im petty sure they wouldnt interchange
  4. Working Class Zero
    Working Class Zero
    Yes, I knew the earlier ones were oval etc. but wondering if actual cluster plate is different?
  5. Working Class Zero
    Working Class Zero
    If they were still oval in early 1930 they still bolted to the same gas tank in 30 as 31?
  6. woodypecker
    woodypecker
    Plate is different
  7. junk yard kid
    junk yard kid
    I just went and checked and the round hole plate wont fit on a 29-29 gas tank. No way no how.
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    The 28-early 30 oval speedometer dash won't fit the Late 30-31 round speedo dash tanks and vice versa.
  9. Working Class Zero
    Working Class Zero
    Thanks guys! For some reason I couldn't find this info.
