1942 11/2 ton Chevy truck weight loading
Discussion in 'The Hokey Ass Message Board' started by OSNABRUCK, May 19, 2013.
  1. OSNABRUCK
    OSNABRUCK
    I have a 1942 Chevy truck that has the MS code, a Conventional Heavy Duty Truck - 160'' WB, 1 1/2 ton flatbed, stake/stock rack , single axle/dual wheels.
    could somebody tell me please what was the maximum weight loading for this truck, thanks
  2. tb33anda3rd
    tb33anda3rd
    sounds like a trick question
    how much weight can a 1 1/2 ton truck carry? 1 1/2 ton.
  3. cobra2
    cobra2
    from dallas
    Feathers or lead?
  4. greaseyknight
    greaseyknight
    from Burley WA
    How are the brakes?
  5. canadianal
    canadianal
    from canada
    I dont know about a 42 Chev but we had a 52 ford 2 ton that had a box and hoist on it . We would haul 200 bu of grain in it regularly 200 bu x 60 lbs per bu = 12,000 lbs. What are you planning ?
  6. OSNABRUCK
    OSNABRUCK
    I just need to stamp a new repro weight plate to replace the one that has been removed at some stage, I want to get it correct and in lbs as it would have been originally
  7. nevrdun
    nevrdun
    from lombard,il
    I don't have any info on the HD trucks for 1942, but I can tell you that the 46 Chev HD trucks with the 160" wb had a GVW of 15000 lbs. The medium duty had a GVW of 13000 lbs. Can't imagine that there would be any difference between the 42 and the 46. Hope this helps you some.
    Norm
  8. hoop98
    hoop98
    from Texas
  9. OSNABRUCK
    OSNABRUCK
    that's great, thanks
