Features The 1955-1956 Plymouth and Dodge Thread
Discussion in 'The Hokey Ass Message Board' started by MrBelvedere2, Feb 12, 2009.
  1. grumpyweasel
    grumpyweasel
    from Colfax, WA
    Does any one know where I can get a long stainless trim piece for a 1956 Plymouth fury front fender? (right front) Thanks for any help you can give.
  2. cozmic
    cozmic
    from uk
    Hi all just found this thread so signed up and thought I'd post a couple of pictures of my 55 sportone 230. Got a bit of tidying up to do but I'm very happy with it, its a genuine three owner from new 58000 mile car all original still on 6 volt positive earth electrics
  3. ramrod36
    ramrod36
    from Upstate NY
    Cozmic---Nice Plymouth. Welcome to the HAMB from New York. I would be interested in how you acquired the Plymouth if you would like to share taht with us.
  4. cozmic
    cozmic
    from uk
    Hi well I bought the plymouth very recently (about a month ago) from a guy near Brighton here in the uk, he imported the car about 2 years ago after visiting the USA to view a different car which was not as good as he thought, he then saw the Plymouth (owned by the same guy) and struck a deal on that. Fortunately for me the guy I bought it from is a bit of a stickler for original cars and has kept it all original, I do like customs and rods but low mileage, original american cars here in the Uk do tend to hold their value better if they are unmolested and I believe the Belvedere isn't a very common car in the uk and it is such a good looking car (in my opinion) that I'm happy to keep it standard
    Charlie
  5. rbmain
    rbmain
    from Newark, CA
    Window gaskets are available from Steele Rubber
  6. Zoomieek
    Zoomieek
    from Delaware
    Hi All,
    New Here. Getting ready to start a total restoration on a 55 Dodge Coronet 2Dr Hdtp. Currently down to a rolling ch***is with just the center section or cabin of the body on it.
    Has anyone ever done one of these ? If so, any wisdom that You may have would be appreciated. I guess at this point the next move should be to replace the body mounts, What vendor has the best ? Anyone know.
    Regards, Zoomie
    I took this car apart so many years ago that I bought a 2Dr Custom Royal Lancer (poor shape) to use as a template guide on how to put mine back together.
  7. MoparFinman
    MoparFinman
    from Okla
    Thats a nice looking 55 Ply. even for a four door it is nice!! Not to Bash 4 doors either, just a lot of people do!!
  8. SteppinOut
    SteppinOut
    Has anyone done a disc brake conversion and used the stock steel wheels over the discs? I am pretty sure they will not clear the calipers but wanted to know before I even think about the disc setup. I probably could look for some steel rims off a Diplomat or 5th Avenue. Any input would be greatly appreciated. Note, I am not building a high horsepower ride but would like brakes that stop the car safely.
  9. Tikiplymouth
    Tikiplymouth
    how does one get the door open on a 56 Plymouth 2 dr wagon when the latch breaks (a spring?) and jams itself shut? The outside handle and lock are removed as well as the door panel. currently pulling the hinge bolts in hopes to get clearances to trip the thing open.:( One of Plymouth's sale pitches for 1956 was stronger door latches that would not spring open in the event of an accident-- I hadn't planned on testing that aspect this way!:eek: any suggestions would be greatly appreciated.
  10. Chris Stapley
    Chris Stapley
  11. SteppinOut
    SteppinOut
    Finally found a parts car with almost all the donor pieces I need to get my 55 Plymouth project back on track. Also found a retired Mopar mechanic to help with the build.
    Woo Hoo!!!!
    Can't wait to drive it
  12. stillrunners
    stillrunners
    from dallas
    Tikiplymouth - are you working on the tailgate of a wagon or ?
  13. PasoJohn
    PasoJohn
    from Edina,Mn.
    I bought my 56 Dodge 2 door hardtop in May 1985 and still have it. Its completely taken apart now and my plans are to get it back together before 2014 so I can take it back to California where I drove it to Paso Robles (West Coast Kustoms car show from Minnesota) in 1994. the picture is from Santa Fe Springs parked at Mooneye's.
  14. 73RR
    73RR
    Send an email or PM to olddaddy.
    www.rustyhope.com
  15. SteppinOut
    SteppinOut
    Thanks!!! Contacted him and looks like we will be doing some business.
  16. PISTON.N.PIPES
    PISTON.N.PIPES
    I still have a few parts laying around from the one i built several years ago.
    i have 2 good brake lamp lenses, 4 arm rests and one rear lower q-pannel if anyone need them hit me up.
    pistons.n.pipes@gmail.com
  17. Munster Motors
    Munster Motors
    getting closer on mine but still lots of work to do:
    just put radiator in and stainless hoses today....but gaining ground
  18. Tikiplymouth
    Tikiplymouth
    driver door is jammed up and after taking the p***enger side apart to see what my options might be, I decided the bear claw latches be worth the effort-- the p***enger side appears to be pending disaster as well.
  19. SteppinOut
    SteppinOut
    Just stopped by to check on my car's progress and my buddy has the 8 3/4 rear end mounted in. Engine is being torn down for a stock rebuild this week and should be in within two weeks. Spent time outside last night working on the valve covers. Haven't sanded parts or prepped for paint in almost 30 years and man it felt great to do it again. Spring fever - catch it!!!
  20. SteppinOut
    SteppinOut
    Just a quick update on the progress. Got the engine mounted and my buddy had some old Dodge Dakota Headers that fit around the steering shaft. This week will be adding new fuel lines and brake lines and starting the 6V to 12V conversion. Saw the car on the ground with an engine in its bay for the first time since 1970. Car sits nice and level. Excited is an understatement.
  21. Munster Motors
    Munster Motors
    Lokar shifter installed, not to fancy on the linkage design tho
  22. bigrickl74
    bigrickl74
    Nice!
  23. Hey Guys and Gals, I would like all the info I can get on putting power steering on my pristine 55 Dodge Coronet 2dr HT. Poor little thing has a 57 392 Hemi hooked to a built 350 turbo trans. Heavier than a 500 pound canary in the front end. This 75 year old can't steer it anymore in a parking lot. I'll try to send a picture of it. Note the Idaho license plate. Sorry, unable to upload pic. Probably due to 75 Years old!
  24. ramrod36
    ramrod36
    from Upstate NY
    beercan---The Chryslers of that era had a "full-time coaxial" power streering with the pump right on the back of the generator. My 55 New Yorker had this set up with the 331 hemi and it steered just fine. It may be something for you to check out. Also, I am currently running a GM power rack on my 55 Plymouth Suburban. Fatman Fabrications sells a kit to do this swap but I am not sure of clearance with the hemi. Good luck with it.
    lc
  25. Thanks Ramrod,
    I'll check it out.
  26. Sperduton
    Sperduton
    from NJ
    Sorry just saw this. On my 56 I had to use an air chisel from through the ouside handle to break apart the latch. My latch broke and jambed up inside the mechanism and there was no way to hit a magic lever and trigger it open. It wasn't going to open unless I busted the latch apart....It took me awhile since I was doing it on a finished car and trying not to mess up my door.
    I've been on the lookout for good extra spare latches since then.
    Nick
  27. Sperduton
    Sperduton
    from NJ
    I Am Running The AAJ Kit Front With Stock Wheels....
  28. Tikiplymouth
    Tikiplymouth
    Finally got the door open! Had to cut the hook part on the door post in two using a center punch and an 1/8 inch drill from inside the car. ( I never did find the "magic" trip mechanism either:confused:). Since it isn't a resto car and I had all the stuff on hand originallyfor another project; bearclaws seem to be the choice. Another mechanical adventure is about to unfold!!-- I hafta to keep the outside handles too...;)
  29. GaryS
    GaryS
    Since my door latches and mechanisms are in pretty rough shape, I'm thinking about converting to bearclaw latches, actuated by a solenoid with the stock handles operating the solenoid. Bad idea?
  30. DepsilonD
    DepsilonD
    Beercan,
    I don't know about 55's, but you could get power steering as an option on the 56's dodges and plymouths (and I ***ume the 55's as well). I picked up a 56 plymouth parts car that has the power steering set-up.
