bagged 63-64 galaxies question
Discussion in 'The Hokey Ass Message Board' started by pride63, May 21, 2013.
  1. pride63
    pride63
    at the moment I am running ridetech shockwaves on the front, firestone bags on back leafs, 5 gallon tank, ridetech 1/4" valve manifold and 2 viair compressors with avs controller.
    question is what dampers have you guys fitted as the shockwaves imo are way too soft , I need to add extra damping to my wagon to help it handle better. any suggestion on what to fit and any pics of where you have mounted them ?
    I will be removing the shockwaves in the winter and fitting new bags , what do you suggest for this as well .
    thanks in anticipation
  2. pride63
    pride63
  3. pride63
    pride63
    No - one running air and dampers????
  4. pride63
    pride63
  5. Jay Tyrrell
    Jay Tyrrell
    Be patient...
    Jay
  6. lgh1157
    lgh1157
    I don't really know about the shockwaves, but if you are gonna do the swap to a double convoluted bag you can easily drop in slam RE6's with a 4" cup ( total height ) and lay frame .
    You can also get some shock mounts and add them behind your spindle , it's tight but it will fit
    L
  7. pride63
    pride63
    Excellent Info , any ideas on what dampers to use as in open and closed size ?
    Any pics to help visualise what I need to do over the winter?
  8. lgh1157
    lgh1157
    With slam specialties you don't need to limited and restrict any travel , they have built in bump stops.
    I will post some links of galaxies and post some pics soon
    L
  9. lgh1157
    lgh1157
  10. pride63
    pride63
    Thank you very much , that's perfect . Top man . All I need to do now is 4 link my back end and get a York compressor. Your help on this is very much appreciated.;)
  11. gimpyshotrods
    gimpyshotrods
    I have now removed 16 pairs of Shockwaves, on the order of dissatisfied customers. Leaks abound, as well as a few total failures. They are just too small for a full-sized car too. Take them out, and run a Slam Specialties SS-6 (more compliant rubber, and an inch more travel than an RE-6), and make some cups for proper ride/rest heights. Run a KYB GR-2 or Gas-A-Just shock absorber(damper) on the side of the arm, and you are good to go. If you have the coin for Bilstiens, go for those.
  12. pride63
    pride63
    Thank you very much , I agree about shockwaves being ****. Will look for ss-6's and kyb gr-2 . ;)
    What bags do recommend on a 4 link rear axle with pan hard bar
  13. gimpyshotrods
    gimpyshotrods
    Slam Specialties SS-7.
  14. lgh1157
    lgh1157
    ^^^ GHR - I love your signature :D
    L
  15. lgh1157
    lgh1157
    gimpyshotrods - Do you have a part number for the Bilstein shocks ?
    Im running RE6's on the front of a 63 Galaxie
    Thx L
