Gauges 6v to 12V
Discussion in 'The Hokey Ass Message Board' started by 55fordf100guy, May 21, 2013.
  1. 55fordf100guy
    55fordf100guy
  2. Saxon
    Saxon
    from MN
    If your bent to convert, then yes you will need something like that to run the old guages. Also all your bulbs will need to be changed, and gen/alt too.
    Also not to be a ***** or maybe i am, but you could have asked this in your previous thread.
  3. 55fordf100guy
    55fordf100guy
    The truck has been converted to 12 v. The guages are stock 6v, is the preferred method one of the parts I linked above or?
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    DO NOT buy that, it is a runtz you would need one on each gauge,Ford used 6 volt gauges up into the 80's this is just for your gauges and will insure proper readings: http://www.ebay.com/itm/1959-1972-F...its=Model:Mustang&hash=item3f13be9bda&vxp=mtr this can be used for all the gauges.
  5. deucemac
    deucemac
    I agree with Jeff, use the Ford IVR and all will be well. Runtz and other aftermarket will work but are lots more trouble to use. Do it like Henry did and it worked from 1928 until 1985! Except for their screw up in 1956.
  6. d2_willys
    d2_willys
    from Kansas
    Ford IVR's work, but are not that good at keeping gauges accurate. And if you lose the ground, then your gauges will burn up, due to a full 12v on them.
    You might want to look into a solid state unit.
  7. Flat Ernie
    Flat Ernie
    Tech Editor
    That Vintique thing you posted appears to be a zener diode. I wouldn't use one of those (and they cost a fraction of that).
    The Ford IVR is a chopper unit and I personally don't like them. They do work, but can fry your gauges if not wired right and you have a failure.
    I prefer a true CVR as described in the 'how to make your own' link posted above. I do all my cars this way. It also gives you the most accuracy from your gauges...
  8. 55fordf100guy
    55fordf100guy
    So:confused:rry which link?
  9. Post #3
  10. leadsled
    leadsled
  11. Flat Ernie
    Flat Ernie
    Tech Editor
  12. 55fordf100guy
    55fordf100guy
    Less than a dollar?
  13. Mercchev
    Mercchev
    Patrick at Patrick's Antique Automotive in Casa Grande, AZ used to sell a booklet on 6v to 12v conversions. Gives step by step instructions even a knucklehead like me could follow. I used it 15 years ago, worked like a champ. Good reference material for the garage library. I would check with him.
    From his website:
    During business hours you can call 1-520-836-1117
    or fax us at 1-520-836-1104
    You may also contact us via email at patstrks@aol.com
  14. Mercchev
    Mercchev
  15. Flat Ernie
    Flat Ernie
    Tech Editor
    Read post 3
  16. 55fordf100guy
    55fordf100guy
    Thanks!
  17. d2_willys
    d2_willys
    from Kansas
    You can build one that handles ALL of the gauges for less than $10!
  18. 55fordf100guy
    55fordf100guy
  19. Not sure why people get in such a huff over converting gauges to 12v.
    A full flow amp gauge should not be used. Period. A gas gauge doesn't care about voltage. It just measures resistance. Same with oil pressure. Unless it's mechanical of course. Temp. ... you guessed it.
    Am I talking out my ***? Maybe. But many 6v-12v trouble free conversions tell the story.
    My avatar has the stock original gauges. No resistors or shunts. They have been working fine for 20 years like that.
  20. yblock292
    yblock292
    Williamson Instruments in Arkansas, great people to deal with, have had 3 sets done by them ,life time warranty............479-369-2551 talk to ron
  21. Flat Ernie
    Flat Ernie
    Tech Editor
    Full flow amp gauges are fine. Only the paranoid and uneducated are 'afraid' of them. All of the car's current flows through a few things - a simple fusible link fixes all those evils. An ammeter shows you stuff a voltmeter won't, but the best is both - unfortunately, most of us don't have enough real estate on our dash and pick one or the other.
    As for a gas gauge just measuring resistance, ohm's law tells us otherwise. Virtually all gauges measure current - even voltmeters. You can control current with resistance or voltage, but if you don't change the resistance and double the voltage, the current doubles. Therefore, your gas gauge will be inaccurate - grossly - and maybe even burn up depending on the design of your system.
    No 'maybe' about it - you are flat wrong.
    Then your car was converted previously. Period.
  22. 55fordf100guy
    55fordf100guy
    Are you saying I should look else where as to why the stock 55 f100 gauges arent working? The sending unit on the fuel tank is brand new, gauge is inaccurate however. Thanks.
  23. 55fordf100guy
    55fordf100guy
    Speaking of electrical parts, any idea what this is? Connects right to the alternator. :confused:
  24. 55fordf100guy
    55fordf100guy
    Searching for model number yields nothing.
  25. No, you should do what these guys tell you. I'm talking out my ***. I did a 54' F100 2 years ago. Stock gauges running a sbc. They still work. They are accurate. I just re-did the entire electrical system in my avatar 6 months ago. Again, stock gauges, no shunts or resisters. Gauges are accurate.
    Guess I'm just lucky.
    Carry on.
  26. I know some disagree with C. 51, but I have the same experience. Converted a '51 Olds a few years back. Just left the gauges hooked up as stock, all read correctly. Put a ballast resistor in the heater feed, and turned the instrument rheostat down. Simple, and stupid cheap.
    Cosmo
  27. Flat Ernie
    Flat Ernie
    Tech Editor
    I = V/R
    Where I = current, V = voltage, & R = resistance
    Virtually ALL gauges are ammeter - they measure the flow of current through the gauge either through induction (overwhelming majority) or bi-metallic strips heating, bending, and moving a gear train.
    Therefore, if nothing changes but V doubles, I also doubles and since that's what you're measuring, well, it means your gauges ain't right.
