65 cheyy ll
Discussion in 'The Hokey Ass Message Board' started by Phil 41 Chevy, May 23, 2013.
  1. Phil 41 Chevy
    Phil 41 Chevy
    Igot my wife a chevy ll 4 door and want to keep drums for now but want to upgrade to a duel master cylinder. Icann' find one listed anywhere so anyboby have a part number or witch one to use . thanx:)
  2. el Scotto
    el Scotto
    from Tracy, CA
    1969 Chevy Camaro/Chevelle with four wheel drums
  3. Phil 41 Chevy
    Phil 41 Chevy
    Thanks, didn't know if the pedals and rod would be the same
  4. fab32
    fab32
    Check the pushrod engagement and piston travel to verify if the new master cyl is compatible with the pedal/push rod during installation.
    Frank
  5. 31Apickup
    31Apickup
    Order one for a 67 Nova, should be a direct bolt in. First year of the dual master, last year of the small boxy Nova. I had a pedal ***embly for a 66 & 67, the push rod looked to be the same.
  6. Phil 41 Chevy
    Phil 41 Chevy
    thanks alot for all the input, I'll give the 67 a try . Thanx, Phil
  7. ratfnk5
    ratfnk5
    from illinois
    When I got mine, Napa had one on the shelf. That was about 2 years ago.
