Best Soldering Gun and Terminals
Discussion in 'The Hokey Ass Message Board' started by The37Kid, May 23, 2013.
  1. The37Kid
    The37Kid
    If you wanted to solder wire terninals who makes the best gun, and who manufactures the best terminals? Best wire would also be needed. To test your soldering how many pounds should the joint hold before braking? Bob
  2. Sealed Power
    Sealed Power
    from TN
    I'm no expert but the old Weller soldering irons get my vote. They get hot fast!!
    I'm talking about the ones with the bakeite case. You can usually find them cheap.
    I'm sure there's new ones that are as good but I haven't found one. I had a new Weller and a new Craftsman neither of them would get hot as fast as the older ones.
  3. Try again .... Welles makes a good dual range unit, good tips, easy to maintain , if not "traditional" use solder less terminals from "Ideal", Thomas& Betts, just go to an industrial supply house those guys won't sell you junk! If you are going for the really old look, ask them for the uncoated copper / br*** units that require solder and not to be crimped. Purchase good flux core solder, brush or sandpaper the terminals and get your wire stripped. The method that works for me on solderless terminals is to tin the conductors first (heat the wire and coat with solder, well getnitnfull of solder) next get the terminal heated, you'll need to thermally isolate it, fill it with solder and while still hot insert the wire. Another way is to heat the terminal then when hot insert the wire and feed the solder from the wire end. Remember that stuff is going to flow toward the heat, away from the cold. Practice with spare wire, you can always reheat the terminal, pull the wire and sling out the terminal, brush it clean and you can still use it again. Oh, as I suggested for solder less terminals, they are crimped, extra solder may make a better flow of electricity, but isn't really necessary.
  4. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I have used lots of soldering guns and pencil type but what I like the best is the mini propane torches. Instant heat and good for heating heat shrink tubing.
  5. brokenspoke
    brokenspoke
    I bought my tinned terminals from " Madelectrical "....I 'm sure there is another source
  6. tommy
    tommy
    I've never been an elitist insisting on the very best of everything. I look for sales. I often use the readily available crimp terminals from the common plastic boxes with the plastic snipped off and shrink tube for insulation. A terminal is not a critical item to me.
    My soldering gun is so old I have no idea what brand it is. The light no longer works but it solders very well due to the operator:D
  7. Weller soldering guns are the best. I was a certified solderer/ examiner trained at Fort Monmouth NJ. for high reliability hand soldering per Mil-S-45743 and WS-6536. I soldered wiring harnesses for all kinds of military applications. Fort Monmouth's training cl*** used Weller.
  8. dirt t
    dirt t
    I do the same. I crimp , solder and heat shrink all me electrical connections.
    TagMan likes this.
  9. manyolcars
    manyolcars
    [​IMG]Tommy is right. Get that plastic **** off of there and use heat shrink. The purpose of the yellow part is 'strain relief'. You will not get strain relief with the yellow **** on your terminal but you will get it with heat shrink
  10. BobMcD
    BobMcD
    Weller is the only one, I would consider. I bought mine over 40 years ago to build slot cars and it still works well.
  11. oj
    oj
    I like an old weller, a big one.
    For soldering terminals i get them from McMaster-Carr, they are uninsulated and tinned.
    Whenever i am at flea market/yard sale etc i glom onto any old rolls of solder and tubs of flux. The lead stuff is disappearing and i want a lifetime supply.
  12. I've had a Weller gun for close to 40 years as well . I use Techspan terminals . By the way it's good electrical conection you're after not physical strength .
  13. GeezersP15
    GeezersP15
    from N.E. PA
    I agree with using Weller. Stick with the very best. Thomas & Betts makes excellent terminals, although you may have to obtain them at your local electrical distributor, where the electrical contractors get their stuff. Doubtful you can get them at Autozone or other auto chain stores. Sometimes they show up on Ebay also. Look for Thomas & Betts, or Sta-Kon.
  14. nxcess
    nxcess
    from Mesa, AZ
    Also vote for Weller. I use nylon insulated terminals ( the kind that you can kinda see through ), YOU CAN HEAT THE RING AND WHEN THE NYLON JUST STARTS TO BUBBLE APPLY THE SOLDER AND IT WILL WICK UP INTO THE WIRE.
    (sorry for the caps, hit the wrong ****on)
    However most wiring kit suppliers and pros are now recommending that you DON'T solder, just crimp with a good crimper. They claim that the wire becomes brittle at the spot where the solder stops and there is no flex area and the wire could break.
  15. The37Kid
    The37Kid
    Thanks for all the replies, but this one is most impressive. So how does one know the soldered connection is good to go? I would do the shrink wrap cover as well. Bob
  16. tommy
    tommy
    practice
  17. klawockvet
    klawockvet
    I have personal experience with broken soldered wires on motorcycles where there is more vibration. Although I soldered things for years I now usually crimp. The key to a good crimp is using the right tool. I prefer the Snapon 29CF. Anchor marine makes crimp terminals with adhesive shrink wrap that will reduce wire tension. They also make tinned wire which greatly reduces corrosion in wet areas. If using the common terminals with plastic covering the first thing to do is remove the plastic and discard, then use shrink tape.
  18. My 2 cents: like others, go to the industrial supply places, T&B, Stacon, Ideal are excellent. Therenisbanreason that new technology solder less connectors have the plastic, it is to provide a total insulated connection after the wire is stripped, inserted and crimped. You MUST have the right crimped, it is different for solder less and soldered, again for a reason, thenwrongncrimper destroys the insulating collar. To the use of soldered terminals, yep, they are insulated after crimping and soldering, so thatnisnwhy so many people use shrink tubing. If you are really looking to do the job as in the early days, buy the bare copper / br*** connectors, strip your wire and practice. These early type connectors also need to be clean, use flux core, you can practice, reheat and sling the solder out again. Remember that the solder is going to follow the heat, so get the wire in the connector and practice, keep the heat on the opposite end from the wire and feed the solder at the wire, connector joint. Weller makes a great dual range unit, works even after dropped, I've made soldering tips from 10 gauge wire hammered to give me a tip and they work. I wish Dave29 would chime in, I'm sure he has techniques an old sub sailor has forgot.
  19. C-1-PW
    C-1-PW
    For the best terminals, buy what the aircraft guys buy. Thomas and Betts, also Tyco are two brands worth taking a look at. If you were to go this route, you would be very wise to use the crimper that goes with each. Over kill? You bet. But unless your idea of a good time includes being stranded at the side of the road, over kill has its advantages. I buy mine from Allied Electric.
    For wire, I recommend checking out the guys at KayJay: http://www.kayjayco.com/index.htm
  20. noboD
    noboD
    Yup, my bakelite housing is all taped together because some idiot dropped it.
  21. chaddilac
    chaddilac
    I use a propane torch... I won't go back to a corded gun type!!!
  22. I used to buy Thomas and Betts connectors at the home depot.
    I haven't set foot in there for years, but when I worked there, they had Ideal and T&B in the electrical department, by the circuit beakers and such.
  23. randy
    randy
    Alright, heres a slight on-topic highjack... A buddy of mine who does computer stuff said that well crimped connections are better than soldered connections because soldered stuff causes a slight voltage drop due to the added material(?). He said they no longer solder joints on aircrafts. Thoughts?
  24. Dane
    Dane
    from Soquel, CA
    I've literally soldered thousands of parts and wires and a Weller has never let me down. The one I have is 30+ years old.
    For battery terminals I use my triple flame cigar lighter. It works great for cigars and battery terminals. [​IMG] [​IMG]
  25. The37Kid
    The37Kid
    That is really going to pissoff the guy a week away from finishing a B-17 retoration. Bob
  26. randy
    randy
    I'm not saying it's true! Just wondering if it's legit or not.
  27. mob53
    mob53
    As an Electronics Engineer who's worked for many companies, not a single one used Weller. They ALL used METCAL. Expensive though.
  28. 40FordGuy
    40FordGuy
    Ditto "Weller" soldering guns.... Bought mine in the late 50's...it still works perfectly !
    4TTRUK
  29. fsae0607
    fsae0607
    Weller Gun!!!
    I just use the bulk terminals they sell at NAPA, O'Reily's, Radio Shack, etc. I always use my Harbor Freight heat gun to soften and then I yank the stupid plastic **** off the terminals. I always crimp, solder and heat shrink. No problems, ever.
    For soldering tips, I just go to Lowe's and buy the clearance solid 12 AWG house wire. Cut a piece about 6" long, strip the insulation off, bend it a full 180° in the middle and bend the tips to fit the gun. I then give it a p*** on the wire wheel to get to fresh, bare copper. I can make tips all day long, since the tips that Weller sells never last.
  30. nmpontiac
    nmpontiac
    from Taos, NM
    You asked about wire - Aircraft Spruce sells MIL-W-22759/16 wire which has tin plated copper strands and Tefzel insulation - 16 ga is around 32 cents a foot.
    When I was working on some prototype UAV's we used wire with silver plated copper strands and teflon insulation - the 16 ga looks like most other 20 or 22 because they make the insulation thinner. Not sure what the cost was though.
    When I was in the Air Force we were still doing "component level" repair, changing transistors, capacitors, etc. Every type of joint had a very clearly defined spec as to how it should look, how much solder, etc. The minimum amount of solder on the joint to ***ure good conductivity saved weight - not much but a complicated aircraft or missile could have thousands of connections, and weight was always an issue.
