Want instal front brakes in my Sprint car, need advice
Discussion in 'The Hokey Ass Message Board' started by barobert, May 15, 2013.
  1. barobert
    barobert
    Hello
    In my 1930s Sprint car I want to install also front brakes. Does anyone from you have some pictures with some ideas and solutions. In my foot room as you can see in the picture is not much place.
  2. barobert
    barobert
    Nobody ever mountet a master brake cylinder in the footromm of his old Sprint Car, or have a picture of it?
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Im sure many of us have mounted pedals in many types of cars with limited room. Its mostly a figure it out as you go. You have to modify the pedal to clear everything AND work with available room with the master cylinder location.
  4. no_fenders
    no_fenders
    Yes a couple of different styles ,, I have some pictures I can send ,, Send me an email at rmichaux at telus.net .. I'm away for the next 3 days so when I get back.. Ron
  5. barobert
    barobert
    Hello, thanks, I have send you a E-mail
  6. barobert
    barobert
    Hi, yes, I'm interestet in the many different types. To modifi the pedal is not so a problem.
    Thanks Norbert
  7. nxcess
    nxcess
    from Mesa, AZ
    Do like the modern sprint cars and midgets do, mount the master cylinder behind the seat.
    You can either mount the pedal at the top ( you would push forward), or at the bottom / rear ( you would push down).
  8. barobert
    barobert
    Tanks for this Info, how does the force go from the pedal to the master cylinder behind the seat?
  9. dreracecar
    dreracecar
    from so-cal
    Most cars of that era used mechanical hand brakes. Mount the handle to the outside of the frame rail through a pillow block arangment with a lever tab pushing the brake rod of the master that is mounted inside the frame rail.
  10. nxcess
    nxcess
    from Mesa, AZ
    It is just a matter of what way you make the lever in relation to the pivot.
    To push back, the lever arm would probably be on the bottom - below the pivot. That way when you push the pedal down, it pushes the master cylinder rod back.
  11. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Maybe a setup something like this would work for you (?)
  12. oldtom69
    oldtom69
    from grandin nd
    one setup that worked well in some of my older cars was a clutch master cyl from a early 60's GMC heavy truck-the aluminum pedal and steel master cyl are one unit that bolts nicely to a flat motor plate.the master actually sits vertically to take less room-they were used often enough that Speedway Motors used to carry rebuilts-dont have a way to post pics or I'd try to locate one
  13. C-1-PW
    C-1-PW
    One option would be to mount two separate master cylinders controlled by a toggle ***embly. One example is the Wilwood Pedal Remote Master Cylinder Mount. Other manufacturers, such as Tilton, also make similar ***emblies.
    Using this system you may be able to adapt your existing pedal. You would need to purchase two master cylinders. On cylinder would control front braking. The other would control rear braking. The pedal mount is adjustable to balance the front to rear bias.
    http://www.wilwood.com/Pedals/PedalProd.aspx?itemno=340-4630
