changed power steering from pump off back of generator to a 1960s or early 70s pump that I mounted to the block, Hooked up the lines and steering wheel cranked itself to the left, I tried to bleed out the air, any suggestionsas to why it did this, it worked before I cnaged the pump over
second one today you have the lines crossed . If you try to stop the wheel it will hurt you real bad. Hope this helps RED
