1954 chevy /350/700r4 LOKAR shifter ???
Discussion in 'The Hokey Ass Message Board' started by 54FISH, May 25, 2013.
  1. 54FISH
    54FISH
    HELLO , I HAVE A 1954 CHEVY 2DR. SEDAN . THE SET UP SO FAR IS A 350/700R4 . I AM USING THE WALTON ENGINE/TRANSMISSION MOUNTS. MY QUESTION IS :I WANT USE THE LOKAR DOUBLE BEND 23" SHIFTER ,BUT WANT MOUNT THE SHIFTER BEFORE TRANS GOES IN . WHICH SHIFTER IS BEST FOR THE SET UP , THE FLOORMOUNT WITH CABLE , THE TAILSHAFT MOUNT , OR THE ONE WITH THE BRACKET WHICH BOLTS TO TOP OF TRANS WITH ROD LINKAGE????? ANYBODY USE THIS SHIFTER , PLEASE HELP , THANKS HAVE GREAT HOLIDAY HAMB ers
  2. can't say for sure, but i would think the tailshaft mount would be too far back and into your seat.
  3. Leebo!
    Leebo!
    from Yale OK
    Dont they have a "universal" option with those that mount to your floor pans?
  4. 54FISH
    54FISH
    I thought that too , thinking cable may be best way , but not sure of clearance between hump & trans ??
  5. briandavy
    briandavy
    I used the the bracket set up with the rod and it worked fine, but that was with the TCI brackets. I guess it all depends on the clearance you have under floor pan.
  6. 52HardTop
    52HardTop
    Use the Lokar that sits on top of the ****** with the rod bracket. I have a 200 4R in my 51 convertible. I used that set up and it works fine. I have bucket seats and a 63 Impala console. Still the shifter is forward enough that it will clear a stock seat. Also my cars have a ****** cover on the floor that I just needed to make a hole for the shifter to come through. Does the 53 and 54 also have a ****** cover?
    Dom
  7. 54FISH
    54FISH
    ****** cover , no ,i was going with stock re covered bench seat , gonna make hole or access plate on hump when i figure out where shifter will be , thanks for your help
  8. 1954chevyguy
    1954chevyguy
    I'd like to know what way works for you cuz I'm thinking of doing this to mine
    Sent from my DROID device using the TJJ mobile app
  9. 1954chevyguy
    1954chevyguy
    I had bought a universal deal and went to try to use it and it wouldn't work so got my money back
  10. UPSrodder
    UPSrodder
    You can call lokar to find out what kind of clearance is needed between the trans and the floor for the cable unit. But you will probably need to use the top of trans mount. You won't br able to "mount" the shifter in the car before you put the engine and trans in, but you can predict where it will come through the floor to make an access cover. But you will have to install the engine and trans mounts in the car, then measure fron the trans mount to the pshifter location to open the floor
