marine 401 nailhead
Discussion in 'The Hokey Ass Message Board' started by chopt31, May 25, 2013.
  1. chopt31
    chopt31
    I ran across a guy that has 2 401's, both from boat, 1 is standard, the other is reverse rotation, what all is involved in changing rotation? thanks
  2. mgtstumpy
    mgtstumpy
    I thought it was just the camshaft, possibly distributor gear and starter motor?
  3. Build a twin-engined FED with 'em.....................
  4. And race it at the Meltdown!!! :D
  5. 48 Chubby
    48 Chubby
    On MOST engines just the cam shaft, starter, and water pump. I have not worked on a marine Buick however.
  6. Rusty O'Toole
    Rusty O'Toole
    I would check the pistons too. Piston pins are normally offset to reduce piston slap. They would have to be offset the other way, or the pistons put in backwards in a reverse rotation situation. I don't know this for sure but it seems logical.
  7. PBRmeASAP
    PBRmeASAP
    That was my first thought too...
  8. slimpick
    slimpick
    Pistons are the same. I did a reverse rotation corvair in the past.
    The distributor gear could be cut the "opposite" way. That way the cam puts thrust on the distributor gear in the correct direction.
  9. Dan Timberlake
    Dan Timberlake
    "That way the cam puts thrust on the distributor gear in the correct direction."
    And keeps the firing order right, and prevents the centrifugal advance from becoming centrifugal retard.
  10. mustangmike6996
    mustangmike6996
    from the D
    At a bare minimum... you have a 401 nailhead block as far as the reverse rotation goes lol.
