'38 ford coupe advice
Discussion in 'The Hokey Ass Message Board' started by arvonian, May 25, 2013.
  1. arvonian
    arvonian
    from Virginia
    Fitted up my 8BA flattie to the 38 to see what issues I might have, and have found that the fan definitely won't fit with the stock radiator. SO, I'm looking for some ideas/ suggestions here. I'm thinking I could mount a pusher electric fan, but don't know if that will provide adequate cooling. I'm sure this is nothing new, so all comments are welcome!
    Willy
  2. cully33
    cully33
    I have an 8BA in my 36 coupe with a 16" electric puller fan, 160 deg thermostat's run cool as.
  3. arvonian
    arvonian
    from Virginia
    Thanks Cully,
    Sounds like that is the way to go. I was thinking pusher so the fan would be somewhat hidden up front. Sounds like a 16 incher will do the trick tho!
  4. 1pickup
    1pickup
    I have an 8CM in my '39 Standard. Tried pushers, pullers, & everything else I could find. Still ran hot. But, I'm sure it's a problem with the engine, not the cooling system. Now, I'm having a 59A built. Guess what I'm saying is, good luck.
