Question about pulling a motor and trans on a 56 buick wagon
Discussion in 'The Hokey Ass Message Board' started by Bruce Fischer, May 26, 2013.
  1. I tried pulling the motor and trans on my 1956 buick special station wagon. Ran in to a snag .The front exhaust cross over pipe kept hitting.I finally got the pipe dropped .Question is it seems like the trans is hanging up.Doi have to drop the cross member for the trans, and is it removeable? Thanks Bruce.:cool:
  2. Frank L. hughes
    Frank L. hughes
    Did you unhook speedo & linkage? Does it have coolant lines? I never worked on a Buick, so I don't know about the crossmember. Frank
  3. birdman42
    birdman42
    Did you unbolt the drive shaft from the transmission? You will most likely have to remove the cross member and pull the rear differential back to disengage the drive shaft.
  4. Frank L. hughes
    Frank L. hughes
  5. zipoleon
    zipoleon
    What birdman says
  6. I looked underneath the wagon the drive shaft is seprated from the trans aready but looks like I will have to unbolt the crossmember for the whole unit to come out.Bruce.
  7. Brad54
    Brad54
    from Atl Ga
    Here's a stupid question... until you miss it like I did on my '54 Buick:
    Did you disconnect the water temp sender from the back of the head?
    There's a heater hose under that that can hang things up, too--it feeds the under-seat heater on the driver's side.
    -Brad
  8. Brad I saw it as I was pulling the motor lol.I had to unbolt the trans crossmember and the motor and trans came right out and I did all by my self. Got the motor and trans high enough and just pushed the wagon back.Thanks to you all for the help.Bruce.
  9. Ole don
    Ole don
    I dont think the Buick drive shaft will unhook itself. Its a torque tube drive.
  10. 40Standard
    40Standard
    from Indy
    you need a couple of friends who know something about working on cars to help you. any local car clubs?
  11. Ole Don the trorque unbolted from the back of the trans and the motor and trans came right out.Thanks Bruce.
  12. 40 standard, little hard to find heip when you live on a mountain top.lol.Bruce.
