??? about a sheet metal brake. who's got one?
Discussion in 'The Hokey Ass Message Board' started by bobx, Oct 4, 2005.
  1. bobx
    bobx
    from Indiana
    ive got a 4 ft box/pan brake, but i dont have the counter weights to help with the bending.
    my question is: how much do those weights usually weigh??
    i can make my own, or if someone knows where to get them..maybe id buy them.
    thanks.
  2. Unkl Ian
    Unkl Ian
    Ones I've seen are at least 5 lbs each.Probably closer to 10.
  3. RonC
    RonC
    from Montebello
    The one on my brake is a cast iron slug about 8 inches long and around 3-4 inches in diameter. It's mounted at the end of a 2 foot bar. You could probably accomplish a similar effect by slipping a longer piece of pipe over the grab bar on the bottom to give you a little more leverage.
