C-6 Shift Points
Discussion in 'The Hokey Ass Message Board' started by Beep, May 26, 2013.
  1. I finally got my Ranchero back running. The 351w with C-6 runs great. However, the shift point on the transmission is way too high. How do I adjust these to lower speeds. Currently it won't shift from 1 to 2 until about 35 mph and then frpm 2 to 3 until about 45.
    Any help would be appreciated.
    Thanks
  2. sidevalve8ba
    sidevalve8ba
    You should be able to adjust the shift modulator. It is a canister looking device with a vacuum hose attached. If you pull the hose off there should be a small screw inside the tube where the hose goes. Honestly it has been so long since I adjusted one of these I forget which way to turn to bring your shifts in earlier. But adjust it one way and if it's worse go the other way. ;)
  3. hoop98
    hoop98
    from Texas
    Be sure you have a good vacuum signal. If it is adjustable CCW will lower shift points.
  4. 432bullet
    432bullet
    With shift points that high your modulator is not working. Check vacuum and see if you have fluid in the modulator, might be a leaking in the modulator.
  5. coolbreeze1340
    coolbreeze1340
    from Indiana
    Yep, what they said! Check the vacuum line first.
  6. chopped 35
    chopped 35
    from australia
    "IF" the modulator is adjustable, screw it out for earlier shifts and in for delayed shifts. rough rule of thumb for a starting point is to have the head of the adjustment screw flush with the end of the vac hose fitting.:D:D:D
  7. 58custom
    58custom
    Make sure that the modulator is connected to manifold vacuum.
  8. blue57ford
    blue57ford
    If you have the kickdown rod connected, disconnect it. It might be hanging in the kickdown position.
