Wood Gas cyl.head
Discussion in 'The Hokey Ass Message Board' started by Heo2, May 27, 2013.
  1. Heo2
    Heo2
    I installed a German Wood gas head (G38tg) on my
    Model A today with 8.5-1 cr
    What a difference.I never Heard a model A idle so smoth
    incredible snappy throtle response. Strong att low rpm
    not much higher topspeed but im fabricating a intake
    for a 11/2inch S.U carb tomorow maby that give me some
    more rpm
  2. gimpyshotrods
    gimpyshotrods
    Are you running wood gas, or just gasoline?
  3. Heo2
    Heo2
    The war is over hahaha... so i use gasoline
  4. gimpyshotrods
    gimpyshotrods
  5. Heo2
    Heo2
    I know there is a bunch of cheap *******s
    trying to run it.....you dont want to be in a
    hurry low Power,have to stop to fill up with
    Wood,dirty, the fumes can kill you,lot of ugly
    things to mount on the car
    I Heard a story about a preast that had a
    Wood gas car during the war
    and some one gave the preast a sack of
    potatos .the Wood for the gas generator
    was also in a sack and the size of potatos
    so in the darknes of the night on there way
    home the driver emptied the potato sack
    in the gas generator.....
    The driver started to curse the god damened
    potatos and the god damened gas generator
    So so my brother Watch your language said
    the priest
    Then fix this without cursing and call me when
    your ready the driver told him and started Walking home
  6. hron13
    hron13
    from sandy eggo
    You don't have to have the generator on your car you could fuel up at your house and go about your business just like a cng, or propane powered car.
  7. BJR
    BJR
    So what is different about the "Wood Gas Head"? Does it raise or lower compression?
  8. gimpyshotrods
    gimpyshotrods
    Up, WAY UP. Stock was 4.1-4.3:1, if you can believe it.
  9. Heo2
    Heo2
    It raise it from 4.66-1 to 8.5-1
  10. Heo2
    Heo2
    Have to have a real big tank then since you cant
    compress it much it starts to fall apart at relativ low
    pressure
    Its NOT a good alternativ fuel they have been experimenting
    with it in Sweden since the war The Army ,several tecnical ins***uts,
    and its about useles
    Well it beats bicycle pedals in a car but....
  11. Hefty Lefty
    Hefty Lefty
    I didn't know a flathead would run very well at 8.5:1 on any fuel but you learn something new every day. I don't think the stock A lower end will like it for very long.
    Wood gas vehicles were still in use in Brazil when we visited there with my dad's business in the very late 60s. They called them "gasogenios". They were burning this hard wood (Brazilian rosewood) from the jungle that today would bring thousands of dollars a guitar set for Martin guitars, I'm guessing they got 1/2 MPG (mile per guitar) making nitromethane a big bargain today by comparison. The gasogenio ran a bus with what looked like an old GMC or International big inline six. This was in a rural area that was like being in the Stone Age.
    My dad said the Brazilian government effectively outlawed them because they were cutting down too much wood to run them. If things ever get so bad in the US we start running woodgas the trees will soon be all gone and it will be like the Dust Bowl again.
  12. Ive got the plans fron mother earth news to build one. It seems the higher compression larger cubic inches the better wood gas preforms. I have a big block engined 72 3/4 ton the best fuel mileage it ever gets is 10 MPG. I plan to use an edelbrock low rise two 4bbl intake one inlet will have a standard gas carb the other a wood gas carb. fuel is plentiful around here. there are big piles of chipped wood the power companies and tree trimmers dump out. there are cull slabs and wood from sawmills & pallett factories. discarded pallettsalso,. And it will also work pretty good on dried horse manure. My horse makes these big stud piles in several locations about the pasture. In building a g***ifier that should have a range of 100 miles on a fill up.
  13. Ned Ludd
    Ned Ludd
    The problem, as many have mentioned, is the need to carry either bulky gas-generator equipment and solid fuel or a lot of gas at near-atmospheric pressure:
    [​IMG][​IMG][​IMG][​IMG][​IMG]
