I started a post before asking people how to find out what cam I have, they said pull the timing cover and look at the cam and there should be numbers for the cam. I pulled it apart and there were no numbers. How do I find out the make and model of the camshaft? Thanks for your help! <a href="http://s722.photobucket.com/user/zschultzy/media/CameraZOOM-20130527150151098.jpg.html" target="_blank"></a>
To start with, you are looking at the wrong end of the cam to see the numbers. They are on the back. If there are no numbers you can find, and you must know the specs, mail the cam and a small fee to Comp Cams and they will run it on the cam doctor and send you the cam with a new cam card. Last time I did it it was about 20 bucks plus mail fees.
Couldn't resist....... http://www.harborfreight.com/36-piece-1-8-eighth-inch-steel-letter-number-stamping-set-800.html Jim
