I'm just about to finish out my disc swap on the Plymouth. Since I already had a late model M/C I shouldn't need to bench bleed it. I pluged the lines under the car during diss***embly. I've been thinking about seting the fronts up with speed bleeders. I found them from Dorman on rockauto for under $10 shipped. Does anyone have any suggestions, comments, or concerns before I proceede. I don't know many people who have used them in the past! Thanks in advance! Nate
All pros no cons. My Son has them on his rpu and it was the first time we had ever used them. Really made it easier and we got a better bleed because it wasn't ****ing air back in. I plan on using them on my own rpu when the time comes. Don
Another positive on the speed bleeders. I used the Russell parts and they do make a one person brake bleed very easy.
Every running vehicle I own with disc brakes has them. First thing I do when servicing the brakes. On my late models I inspect the brakes every 20K, deglaze rotors, scuff pads, regrease, re***emble, bleed off 1\4-1\2 qt of fluid on each corner. Friends think I'm crazy.
I have them on my car and it makes self bleeding brakes so easy. 3 years and no trouble yet. I will be putting them on my other cars when I need to bleed brakes.
As close as your nearest telephone. http://www.summitracing.com/search/...uct-Line/Russell-Speed-Bleeders/?autoview=SKU Don
right on i'll pull one out tomorrow since i need to bleed brakes anyways after im done with the drums and greasing.. thanks Don
Putting them on my daily when I do the disc conversion and rear brake rebuild this summer. I cant get anyone to help me bleed brakes either!
there were some realy cool ones posted the other day that had a screw with a seal and a hose ****** where were they
Ok stupid question then...How the hell do they work? I understand they have a check valve that allows the air past and not the fluid, but do I just crack them open then re-tighten after I'm finished or what. It just seems too easy to be true! Obviously I haven't done my research on these yet! Sent from my DROID device using the TJJ mobile app
I ***ume you still have to do one wheel at a time? Sent from my DROID device using the TJJ mobile app
I wonder if this product would work when bleeding a hydraulic clutch with an external slave cylinder?
They let air AND fluid out, just the same as bleeding with a normal bleed screw. The coated threads and check valve just won't allow it to **** back in.
They let air AND fluid out, but the check valve prevents any air from getting ****ed back INTO the wheel cylinder when the brake pedal is released. So you just pump the brake pedal a few times, close the valve, refill the M/C reservoir, and move on to the next wheel..
Ok that makes more sense! The way it was explained to me was no fluid comes out! Thanks all! Sent from my DROID device using the TJJ mobile app
Originally Posted by n847 Ok stupid question then...How the hell do they work? I understand they have a check valve that allows the air past and not the fluid, but do I just crack them open then re-tighten after I'm finished or what. It just seems too easy to be true! Obviously I haven't done my research on these yet! __________________________________________________________________ Yep, we found you can turn them loose a bit more than the directions say and you get a better flow. The special sealant on the threads keeps air from going back into the wheel cylinder, as does the check valve inside the bleeder. I immerse the rubber hose end into clean fluid so I can see bubbles coming out, and when you see no more bubbles you tighten down that bleeder and move to the next wheel. Although one person can do it by themselves it is still easier with two as one can be watching for bubbles in the fluid coming out and also making sure the MC doesn't run low on fluid while the other person pumps the pedal. The biggest advantage IMO is not having to continually be loosening and tightening the bleeder as the pedal is pumped. You just loosen it a little till fluid will flow, then you don't touch it again until you are done with that wheel, at which time you retighten it. Don
I added speed bleeders to the wife's MGA a couple of months back when rebuilding the brakes. They worked great but I just couldn't get a solid pedal. Remembered a deceptively simply tool I used to use back in the UK as a kid, the Gunson Ezibleed system. You pressurize it from the closest tyre to the M/C. Hooked it up and hey presto, solid pedal in a few seconds. Could also be used instead of speed bleeders. http://www.gunson.co.uk/item.aspx?cat=664&item=1818 There is a company here in the US that sells it now. If anyone needs contact info I will post it.
