Hot Rods Help me ID this Ford V8 pickup frame
Discussion in 'The Hokey Ass Message Board' started by Fast67VelleN2O, May 27, 2013.
  1. Fast67VelleN2O
    Fast67VelleN2O
    Like the ***le says. What year is this?
  2. need louvers ?
    need louvers ?
  3. Fast67VelleN2O
    Fast67VelleN2O
  4. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Grab it, other than a few holes, its the same as a car frame.
  5. Fast67VelleN2O
    Fast67VelleN2O
    Whats it worth? Fair market value. Guy tells me to make an offer.
  6. treb11
    treb11
    looks pretty crusty. $250 bed included if there is rot at the juncture of the x-memb an the main rails flathead is probably full of water. maybe a little more if all is solid and the engine has been covered.
  7. carmuts
    carmuts
    Looks like it has a later flathead in it. Possibly a 37-38 LB block, judging by the number of stids and the waterpump placement. Rod
  8. LSJUNIPER
    LSJUNIPER
    from ct
    It has the distributor from 37 to 41 too....
  9. Carter
    Carter
    Pretty sure that's a 24 stud
    Sent from my DROID device using the TJJ mobile app
  10. carmuts
    carmuts
    May have miscounted, will have to look later when back on my regular computer, can't see enough detail on the phone. Rod
  11. alchemy
    alchemy
    Looks like the frame horn is splitting. Probably a lot of rust in between the layers. And the tin patch over the side of the frame rail is suspect too.Look it over very closely, and see if you can handle the damage.
    The flatty is a solid hunk of rusted 24 stud, guaranteed.
    Bed looks rather rusty as well.
    I'd say there's $200 in parts there, but there is a whole lot more work there as well. But I've been known to bring home rustier stuff.
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes it a 24 stud. Probably cracked since its exposed to the elements.
  13. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Looks like the drivers side before the kick up has galvanized metal rivited on it ?
    Beat me to it !!
  14. 49ratfink
    49ratfink
    what is the car next to it?
  15. Fast67VelleN2O
    Fast67VelleN2O
    I don't know. I'll get more pics today.
  16. Atwater Mike
    Atwater Mike
    24 stud, (look at the lower center 2: 24 studs had 2 at the center, thusly: 21 stud engines had 1 in the bottom center. Fast way to tell.
    This one also has a late '39 ******. (look at the shift tower and stick)
    Yeah, the galvanized 'side skirts' might be there for a reason...
  17. Fast67VelleN2O
    Fast67VelleN2O
    Here is everything that is for sale. Just got drug out over the Memorial Weekend.
