need ideas for a cool steering wheel,,,65 F100
Discussion in 'The Hokey Ass Message Board' started by Kustom7777, May 28, 2013.
  1. Kustom7777
    Kustom7777
    from Austin, TX
    i HATE the stock steering wheel in my 65 F100, i don't want to just replace it with a moon sparkle steering wheel (although i do like them),,,looking for something different....what kind of ideas do you guys have?
  2. Zapato
    Zapato
    I'd be looking for a 59-61 olds , buick or pontiac they have a really nice deep dish. olds be my first choice of the 3, if not one of the semi square Chrysler wheels. have to agree most of those ford truck wheels are really plain jane.
  3. Kustom7777
    Kustom7777
    from Austin, TX
    i have one of the semi square chrysler wheels (imperial),,,it's already slated for the telstar..........it seems i'm limited to ford/lincoln/mercury wheels due to the splines interchangability, unless someone knows something i don't.....
  4. bstie
    bstie
    I like the moon sparkle wheel idea but throw a bullet on it so it matches the spider caps you put on there... heres one I did for my stude,
      489.3 KB
      497.7 KB
  5. n847
    n847
    I think the early to mid 60's F series trucks have killer wheels to begin with, I'd just flake that 2 tome and rock it!
  6. '61 impala wheel would be cool.
  7. Tony Ray
    Tony Ray
    heres a pic of mine..think its a dodge with a bullet attached
  8. Kustom7777
    Kustom7777
    from Austin, TX
    how did you adapt that dodge wheel to the ford column? or is it a dodge column?
  9. rld14
    rld14
  10. I'd just go see what I could find cheap. 55-57 Ford car wheels look decent enough.
  11. Squablow
    Squablow
    Pipes' wheel is a '57 Plymouth if you're going for that.
    My '52 has a '59 Ford wheel with a '57 horn ring, I like the '59 wheel because it has a nice area to break a two tone paint line on it, and the horn ring I just had. Should fit the pickup spline.
    Not the best pic I guess but it's all I have at the moment.
  12. Tony Ray
    Tony Ray
  13. fca2572
    fca2572
    from Texas
    This is the wheel I want for my 57 F-100 it is off a 1962 F-350
  14. galamabx
    galamabx
    from london
    I like the moon sparkle wheel idea but throw a bullet on it so it matches the spider caps you put on there[​IMG]
  15. Fedman
    Fedman
    Like Squablow, I love the 56-59 Ford Wheels, and they are a direct swap.
  16. Mr cheater
    Mr cheater
    How about a 1960 f100 custom cab steering wheel. Painted with red metal flake.
    Sent from my DROID device using the TJJ mobile app
  17. Mr cheater
    Mr cheater
    So the picture didn't show up
  18. Fedman
    Fedman
    Very Nice!
    What paint did you use?
  19. Mr cheater
    Mr cheater
    Krilon glitter blast did it this winter so some time will tell how it holds up
  20. Caddy-O
    Caddy-O
    47 Pontiac wheel:
  21. I scratch built this one! 120 pieces of wood, 15 stainless rods, a stainless ring, an aluminum center and some ***orted hardware and a weeks work. 18" diameter for my truck.
  22. MLG
    MLG
    Here's my 60 Ply Aero.
  23. 49-51 Lincoln. Direct bolt on.
  24. 1951Biff
    1951Biff
    woolfcreek, that steering wheel is so freaking cool! Got any more progress pictures? What type of wood did you use?
    Fantastic work man!
  25. Squablow
    Squablow
    I have one of those for my Fury that needs to be recast, quoted $1600 for the job. Have seen nice ones like yours bring about the same money. Hope it didn't have to get cut to put it on that column, where did you find it?
  26. I used ziricote on the back, amazon rosewood on the front and the white divider pieces are hard maple. It is a one off, because I'll never do one that complicated again. I expect the wood on it to go to hell with time, so when that happens I'll wrap it with leather or coxcomb it.
    http://www.frayedknotarts.com/tutorials/coxcombing/simple.html
