1940 ford female door dovetails how to replace
Discussion in 'The Hokey Ass Message Board' started by mooringr, May 30, 2013.
  1. mooringr
    mooringr
    from md
    how do you replace the female door dovetails 1940 ford coupe?
  2. 39 Ford
    39 Ford
    Without looking at my car seems like they are held in with a couple of screws. Look at yours it should not be too hard to figure out.
  3. alchemy
    alchemy
    IIRC the two tails themselves are replaceable as well as the springs behind them. I think you push the tail into the body, and slip the outer end past the little retainer tab on the edge of the V opening.
    There might be somebody reproing the inner housing that rivets to the backside of the door jamb, but I've never seen one.
  4. Old Tin and New Tin
    Old Tin and New Tin
    alchemy is correct on replacement of the dovetail and spring.
    If you need a replacement "metal pocket" in addition to the dovetails and springs they used to be available through C and G Early Ford Parts, Escondido, CA.
  5. mooringr
    mooringr
    from md
    metal pocket & dovetails need to be replaced well guys mine are riveted & spot welded to the door jam it was fun & there are out now!!!!!!!!
    BOB
  6. oj
    oj
    You might give **** Spadaro a call, he is a regular here and has lots of 40ish Ford stuff, all high quality.
    I'm sure he is an alliance vendor, check thier index for a number.
