Battery and welding. DANGER !!!!
Discussion in 'The Hokey Ass Message Board' started by nali, May 30, 2013.
  1. nali
    nali
    I was welding on the alternator bracket.
    Suddenly, explosion in the garage !
    The battery was connected to the charger and exploded . Hot and acid smell. I had to vent 15 minutes before returning in the garage.
    I first thought the - was connected to the ground, it s not the case.
    I don t really understand what happened ....
    Conclusion : don t be as stupid as I ve been, disconnect when welding ..
    Enjoy ..
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    VERY VERY simple! the battery being charged was producing hydrogen gas and a welding spark lit it off.
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Consider that an easy leason if nothing major got damaged.
  4. badshifter
    badshifter
    I would have disconnected the alternator bracket and welded it on the bench.
    Good you're ok.
  5. tfeverfred
    tfeverfred
    That's one of the first safety rules I was taught at welding school. Glad you weren't hurt.
  6. nali
    nali
    Maybe hydrogen ...
    But I was welding 2 feet away from the battery, and the caps was on it. I find surprising the arc from the welder could ignite from so far.
    Fact : lesson learned . It was a quite new battery :(
    At least there s been no other damage or injury.
    In fact, my mind was on the bracket I make and I totally forgot about the battery .
  7. drunkandgreasy
    drunkandgreasy
    from nunya
    Yeah. If your charging a battery, it will "gas" and it will explode on you. My buddy warned his boss, his bosses reply was "shut up monkey, I'm in charge".....cuz he was a ****, two seconds later, blam! The motor cycle battery he was standing over while doing something electric blew up in his face, covered him in acid, ruined the customers paint, he went to the ER, messed him up bad. 2nd degree burns, lucky he didn't go blind!
    Careful fellas...
  8. nali
    nali
    It was connected to the charger since yesterday, so I suppose charged. In this case, there s not much gas and bubbles forming.
    It seems it was enough .
    But I don t think it s the reason. The battery was really hot. If the explosion was caused by hydrogen, the heat would not warm the whole battery. No time enough for this.
    Put a pint of fuel on a half gallon of water in a bucket and ignite it. It will take time before the whole water goes to 110 Farenheit. I didn t measure the temp, but it was between warm and hot.
    For some reason, I think it received the voltage from the welder.
  9. 400 4spd.
    400 4spd.
    I've been witness to 2 exploding batteries. Both times they were being charged and unexpectedly went off. Both disintigrated the cases and the sound was similar to a 12 gauge at close range.
    I respect the power of a car battery.
  10. samurai mike
    samurai mike
    don't forget that bumping the clamps on the charger will cause sparks also.
  11. Fuel to burn
    Fuel to burn
    Were you arc welding? Maybe you got close to the battery wire and gave it a little extra voltage?
  12. flathead lugnut
    flathead lugnut
    from seattle
    Remember the Hindenburg????
  13. You asked what the heck happen and now your doubting what everyone is telling you .. next time you might not be so lucky, good luck with that.
  14. NickJT
    NickJT
    from S.E. PA
    Hindenberg & Hydrogen remind me not to allow sparks near batteries.
  15. nali
    nali
    MIG. The ground was connected 4 " away from the tip.
    I know this is a stupid incident. We always think it will never happen to us . Only the stupid "others " .
    I just forgot about the battery ......
    No damage, no injury. I may even save it by sealing with epoxy :)
    Always good to take mention of the risk .
    It really make a huge sound. I supposed my neighbor think I suicide tonight with a gun :p
    1 1/2 hour later, I still have bees in the ears :p
    Nice side effect : we have a lot of mosquitoes here since 3 days. The acid vapor made them leave the garage :p
  16. harpo1313
    harpo1313
    from wareham,ma
    Acid proof apoxy ,good luck with that one.
  17. nali
    nali
    Yeah ...
    It would probably more expensive than a new battery :p
  18. D-man313
    D-man313
    So this battery was out of a car on the bench, charging, right? Sparks form welding made it ignite? I've heard of battery's blowing up if hooked up in the car and welding on the car.
    Just trying to get this straight in my head, for future reference to be safe in the shop.
  19. nali
    nali
    In fact I posted this a a reference for safety.
    I always take care about this.
    I ve working as a carpenter, machine shop and others funny things. I still have 10 fingers, 10 toes and 2 eyes :p
    I have to be in shape for my kids . Gabriel is 7 y/o today the 30 May ..
    We all think accidents happen to stupid guys we see on the Fail compilation on Youtube.
    We all think stupid things won t happen to "US" Me. You. . We are so careful, so clever that just idiots redneck hurt themselves working on their car ...
    Darwin Award is also a nice source of inspiration.
    I just forgot about the charger and BOOM .
    For info, it s a 1966 car. so OT here. A Rambler Amb***ador in which I swap a 258 from a 1978 Concorde, a TBI through modified Rochester B as throttle ( 3 in fact , 2 for the injectors and one for the IAC ), and a M62 Eaton supercharger.
  20. no.scar.no.story
    no.scar.no.story
    I saw this once in a log truck getting a welding repair - while the battery was in the truck, connected. It blew the lid off the battery box, and destroyed half the battery. Also, I had a battery detonate under the hood of an O.T. Jeep while I was driving it - and I thought (at the time) it was from overcharging from a faulty regulator. Was the charger set on a high or trickle setting?
  21. nali
    nali
    I measured the charger output. i give a nice 14.5 volts.
    I ve had once a bad regulator, and the battery dropped to 17 volts.
    I won t say it liked it ...
    But it didn t explode. Nor overheat.
  22. nali
    nali
    I m a former "electro mecanicien" ( don t know the english word, I m french ) and been working for years in electronic.
    I know how to use a meter.
    I didn t find any reason yet ..
  23. 2 things i see wrong; 1 charging with the caps on ..big no no, nowhere for it to vent and pressure will build up while charging, 2 welding near a charging battery another big no no, as stated sparks make them go BOOM!! Always pull the caps off and charge with them off so you don't build up pressure and explode it, also never weld near a battery, aerosol can; ie wd40, starting fluid ,paint etc, them little spit balls will melt through things you would never expect them to.
  24. nali
    nali
    I totally agree.
    It was not a nice idea.
    But who doesn t make any mistake ?
    Read above. I usually take care ..
    All the inflamable liquid or gas are stored outside my garage. To avoid the BOOM effect.
    There s even not a single piece of paper or fabric here ...
    **** happens .
  25. What the hell kind of welding gas did you get now ?!?!?:)
  26. nali
    nali
    For now I m using a mix of sulfuric acid and Argon mix. Works quite good :p
  27. Motomike43
    Motomike43
    Had nothing to do with the battery being hooked up. Never have any open flame or spark near any battery. Yes, they will explode. your lucky you had your welding helmet on. Acid + eye = BAD!
  28. Glad you are alright and making jokes.
    That could have been really painful
  29. nali
    nali
    I m building this thing ...
    OT cause it s a 66.
    This is a Photoshop, of course.
  30. GassersGarage
    GassersGarage
    I use to do Commercial Traffic Enforcement. All exposed batteries required a cover just for those cir***stances. When I had a bracket welded on my '32, the first thing the welder did was disconnect the battery. And that was with a battery in the trunk that was covered too. The bracket that was welded was on the front end.
