to shave or not to shave
Discussion in 'The Hokey Ass Message Board' started by 4rod, Jun 1, 2013.
  1. 4rod
    4rod
    okay, so thought I'd post this question outside the build thread to get as many pics and thoughts on shaving the trunk hood latch on the 50...I'm not shaving the door handles however am chopping and have done some subtle stuff...I'm all ears and eyes for suggestions...
    without...
  2. lucky-13
    lucky-13
    from Sacramento
  3. Special Ed
    Special Ed
    yep ...
  4. Dreddybear
    Dreddybear
    Yep
  5. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Shave it for sure. That piece is bulky and doesn't flow at all.
  6. Dane
    Dane
    from Soquel, CA
    What they said. Smooth :cool:
  7. Racer29
    Racer29
    Normally I like to leave all the stock pieces as much as possible but in this case I think shave it. It does kind of "stick out there" and not in a cool way.
  8. BLUDICE
    BLUDICE
    Shave it, nose it, deck it, and drop it in the weeds!
  9. engine138
    engine138
    from Commack NY
    Dont shave your head but shave the car
  10. Bigcheese327
    Bigcheese327
    To me the trim is a big part of the appeal of an old car. Shave everything off and you're just left with a big lump.
  11. 4rod
    4rod
    yeah...Rodger Cunningham's 50 looks pretty cool...I also, like the rounded corners...
  12. 4rod
    4rod
    I'm sorry embarr***ed, but don't know the terms "nose or deck it" could you explain that to me...
  13. sko_ford
    sko_ford
    Too clean up or remove the trim on the nose or decklid. I dig that suround but im a bit goofy.
  14. raidmagic
    raidmagic
    Wow yeah that needs to go. Of course you could leave it there and eat your lunch on it, that thing is HUGE. Maybe that's where the ricer wing came from
  15. Cruiser
    Cruiser
    [​IMG] Shave it................................... CRUISER :cool:
  16. gassersteve
    gassersteve
  17. twenty gallons
    twenty gallons
    you can always do what I did to my Daughters 53 Chevy
  18. 4rod
    4rod
    well, so far its unanimous...its gonna hang in the wall art...so now for the insight...trunk goes to a popper for opening? or is there some ingeniousness?
  19. BRENT
    BRENT
    And dont forget to get rid of the license plate indent aswell! I filled mine in on the 1950 really smooth's things out in my opinion.
    Brent
  20. I'm not a shoebox lover, so the more you do to change the look, the better it will be. (other than a ricer wing)
  21. Munster Motors
    Munster Motors
    Leave it, it adds character
  22. 4rod
    4rod
    ha...you got it wolfcreek...
  23. beyond static
    beyond static
    from Louisiana
    Definately shave it. I plan to run a modern style latch, and have a pull cable routed behind the bumper to open it.
  24. shoebox50
    shoebox50
    Shave it
  25. 4rod
    4rod
    static...that was my guess...when you shaved yours did you cut out the indent for license plate and reverse it?
  26. BadLuck
    BadLuck
  27. 4rod
    4rod
    shoebox50...wow...inspiring...love the chop...and yeah...nice,smooth, tight rear
  28. beyond static
    beyond static
    from Louisiana
    I left the indent in place for strength. I was worried about it warping if I cut that piece out and welded a new piece in, so I left it in place and bent up a piece of sheetmetal to weld over it.
  29. 4rod
    4rod
    good idea, although in wetter climates trapped moisture might be an issue down the road...thanks all for the suggestions...getting at it in the am! will post pics in my build thread
