1960 chevy truck
Discussion in 'The Hokey Ass Message Board' started by zacattack, Jun 2, 2013.
  1. zacattack
    zacattack
  2. It's not a 60 unless it has torsion bars,post some pic's of truck.
  3. zacattack
    zacattack
    heres a photo of the truck
    zac.
  4. 1960 ,61 &62 checy trucks came originally equipped with torsion bars. Its likely someone swapped the whole suspension & K member for a 63 up op unit. They just bolt in and Ive did a few myself.
  5. 5559
    5559
    from tn
    if it does have coils then your in luck, you can use coil springs up to 1987 c 10.Also i've been told you can get a minor drop from using 67 or newer spindles-if you use the later model ball joints--don't know about this for shure-. but it might be something to check out.
    but i know the fronts will work
  6. zacattack
    zacattack
    awesome thanks guys that helps me out alot:D
    cheers Zac
