Flathead Guru's - What oil to use in fresh rebuild?
Discussion in 'The Hokey Ass Message Board' started by Bull, Jun 3, 2013.
  1. Bull
    Bull
    Will be firing my freshly rebuilt flatty tomorrow. I've got a case of straight 60 weight VR racing oil from Valvoline. Would this be appropriate for a fresh rebuild or should i look to their 20w50 as others have used?
  2. alchemy
    alchemy
    I use straight 40w per my engine builder's direction. I use the Valvoline VR-1 stuff, and throw a can of that ZDDP in for good measure.
  3. cs39ford
    cs39ford
    When Mine was fresh I used Val 40wt Now I use 20/50 wt Since I have Hi vol oil pump, The other wt oils seem to bring oil press down Like to see at least 40pd at idle This motor has been running since 1990 that way, About 80th miles now
    Hope this helps you
  4. Bull
    Bull
    So 60w VR-1 will be too heavy I'm ***uming?
  5. cs39ford
    cs39ford
    Not sure on 60wt, Should call a flat engine rebuilder and ask, I had good luck with 40wt I did my motor my self So not a daily thing for me. Never hurts to ask
  6. terryble
    terryble
    from canada
    Ever try to shove ****er up a wildcat's *** it's better if you melt the ****er! 40,50,60 are for broke in motors, warren out ones or extreme temperature conditions. Run 20w,10w30 0r even 20w50 but make it light enough it gets everwhere as soon as possible! Add zinc and run it til its hot and drive it a least a hundred miles before changing. Heavy oils are for extreme conditions or tired motors fresh ones need light oil.
  7. thunderbirdesq
    thunderbirdesq
    20w50 with a half can of STP for the zinc for peace of mind....
    Benji Gutierre likes this.
  8. Ole don
    Ole don
    Rotella 15 W 40. Unless you know the clearance in the bearings, and it wide, save the 60 wt for a race motor with the wide clearance.
  9. Feo
    Feo
    Quaker State 40w
  10. Bruce Lancaster
    Bruce Lancaster
    Any modern oil will be fine, but stick to 30 or a multigrade. 60 is waaay too thick. I've posted how to put in the last coupla quarts via the sender port so that you have absolutely instant pressure at fireup.
    I ***ume cam lobes were greased up with ***embly lube made for that purpose...I would if so consider that part done, engine should be fine forever on regular modern oil after run in.
    Old way...posted forever by old Honest Charley in his catalog...was to put in an extra quart for break in so cam got extra splash, but even though traditional I would not do that because the extra splash oiling could jeopardize ring break in.
  11. TORCO makes a break in oil that has been specifically blended for the express purpose of maximum protection during initial break in. Look them up on the internet at torcousa.com.
  12. Flat Ernie
    Flat Ernie
    Tech Editor
    You can never go wrong following Bruce Lancaster's advice. I second the 30W and well-greased cam/lifters - that's how I do all engines (not that I've rebuilt anything in the recent decade).
    Oil is cheap insurance. I always did my initial run-in and the first 30-50 miles and then changed oil. If you have a filter, it will be full of ***embly lube at this point. I then put in another 30W fill and ran that for 100-250 miles. After that, I changed as normal...
  13. Bull
    Bull
    I ended up with 20w50 VR-1 and a bottle of Lucas zinc additive.
  14. Gene Boul
    Gene Boul
    I like 20W / 50W Pennzoil or such. I pack the oil pump with white lube and spin the motor over a bit before turning on the juice. After it's got a few hundred miles on it I use Rotella 15W / 40W. Truthfully the modern oils are so good you almost can't screw it up!
  15. HOTRODPRIMER
    HOTRODPRIMER
    I used 40 WT in mine. HRP
  16. Chris
    Chris
    I use Lucas Hot Rod oil in mine. Full of zinc, designed for flat tapped engines and comes in 10w30, 10w40 and 20w50
  17. Why put ZDDP additive in VR1? Doesn't make sense. VR1 already has recommended levels, and it has been proven scientifically that adding extra actually reduces the effectiveness. :confused:
  18. Pete1
    Pete1
    from Wa.
  19. CheatersPete
    CheatersPete
    Always used 20w50
  20. Most 20-50 or straight 30W mineral oils with do the job. Remember gang, FHs dont have killer valves spring pressures to contend with, so a good minerl oil that had some zinc in it will do the job. An additive cant hurt if youre paranoid.
    One more thing. Cam lube on cam lobes/lifters will block up the oil filter after it melts off the lobes / lifters during break in. If you're running a lifter it will clog the lifter.
    If you're running a filter, break in the cam, dump the oil while hot, add fresh 20-50 or whatever you used THEN drive the car to load up the rings properly. Hell even if your not running a filter do it.
    Then after 50-100 miles dump the oil.
    Why would anyone want to DRIVE the car around for 100 miles+ with a clogged filter AND the oil they broke the cam /lifters in with defies logic, esp with all the "metal" in the oil after cam break in. sp when its just for the sake of an oil change/filter?
    Rat
  21. Bruce Lancaster
    Bruce Lancaster
    Easy priming for a new flathead: Right before startup hook a 1/4" pipe fitting to a hose from a coffee can...lash this up any way that is easy. Hook it to port at back of block. Port is hard to reach on many cars, consider also hooking up to the feed pipe up top if you have a stock filter.
    At any rate, put the last 2 quarts of oil into through the can rig, which will fill galleries and prime pump. You can't see or directly tell whether you get everything this way, but I believe you do, because when I do it I see movement on the pressure gauge on the first movement of the starter, and engine goes to full pressure immediately when it lights.
    Don't forget to re-plug your oil system before you touch that starter ****on!
  22. 40FordGuy
    40FordGuy
    Ditto on what Bruce Lancaster said........ I always put in a zinc additive.
    4TTRUK
  23. rosco gordy
    rosco gordy
    I have had great luck with brad penn 50
  24. I use Caterpillar Diesel Engine Oil (DEO) 15W40 has plenty ZDDP.
  25. Flat Ernie
    Flat Ernie
    Tech Editor
    Brad Penn is arguably the best non-synthetic oil out there. I wouldn't, however, use their 50W for initial start up. They make a break-in oil:
    http://www.penngrade1.com/Products/High-Performance/Break-In-Oil.aspx
    Brad Penn is the old Kendall green. Conoco-Phillips bought the Kendall name, but not the actual oil. Brad Penn is done in the same refinery with the same petro-chemists as the old Kendall 'green slime'. Good stuff and worth the price for most high performance engines...
