Vertex Magneto ID?
Discussion in 'The Hokey Ass Message Board' started by chris98006, Jun 6, 2013.
  1. chris98006
    chris98006
    from Seattle WA
    Any Ideas what this is off of? I thought it was a Banger, but no luck- Thoughts?
  2. chris98006
    chris98006
    from Seattle WA
    More Pic of the Magneto-
  3. Bruce Lancaster
    Bruce Lancaster
    No idea at all...but it looks like it would be easy to adapt to an A or B by shortening the shaft and milling it to a drive tab and adjusting the shank to diameter of B distributor.
  4. chris98006
    chris98006
    from Seattle WA
    Thanks Bruce- I was told it's possible, by a few different people. That might be what I'll end up doing. I sent some pics to H&H and they thought it could have been used for an old Cosworth.
  5. Rookie1
    Rookie1
    Vertex is in Blue Bell,Pa. I used to send them back for a tune up.
  6. oj
    oj
    Looks to me like it might be an external-driven magneto. is that a keyed shaft with a nut to hold a pulley in place? Then you'd just have a piece of slit tubing to pinch the dark part of the base and run a belt to the crank or whatever, i've seen deisel turbo tractors coverted to alcohol and sparkplug/magneto ignitions clamp the magneto to the head and let them hang out over the front of the engine to be driven.
  7. drtrcrV-8
    drtrcrV-8
    Try Hunt Magnetos in Sacramento,CA, both for service & for I.D. of unit
  8. chris98006
    chris98006
    from Seattle WA
    Tried them, no dice-
  9. chris98006
    chris98006
    from Seattle WA
    I was told Vertex was bought by Taylor. I called Taylor an they don't have a lot of records from Vertex because at some point their building caught on fire and do***ents were lost.
  10. chris98006
    chris98006
    from Seattle WA
    Thanks! Interesting, never thought about that-
  11. christmas tree
    christmas tree
    Make sure the rotation is correct for your application. They will spark going backwards but the internals are directional.
  12. chris98006
    chris98006
    from Seattle WA
    Thanks- Yeah, if I am not mistaken the rotation is different for VW's, etc.
